Project 2G 8's and Street Driven
Old Feb 3, 2012 | 07:53 AM
  #31
TALONGT's Avatar
Modifed my JMF block off plate to accept a AN fitting via a 1/2" NPT. Milled the hole, then machined a fitting to fit and tig'd the fitting into place
Milling hole for press fit fitting
Fitting machined for tolerance fit in block off plate also fitting tapered to enhance flow
Fitting pressed into block of plate
Fitting Tig'd to block off plate
Old Feb 3, 2012 | 10:08 AM
  #32
domestickillaAR's Avatar
Sub'd
Old Feb 7, 2012 | 10:56 AM
  #33
TALONGT's Avatar
Found another grey silver headliner for a non sunroof and am switching it out for my sunroof headliner in my car. I dyed the headliner black should look alot better then the old one.
Old Feb 15, 2012 | 08:14 PM
  #34
TALONGT's Avatar
Made some more progress on the cage today almost done heres a sneak peak
Old Feb 18, 2012 | 02:37 PM
  #35
TALONGT's Avatar
So with the 5 or 6 projects going on at the same time I thought I would post some interior teaser pics
Old Feb 25, 2012 | 07:27 AM
  #36
TALONGT's Avatar
Some people have been asking what the fittings I made are for so here is some more info and pics to clarrify that.
I'm going to be running coolant directly to my head this year so instead of just welding some AN fittings on I decieded to make something that can not only be switched to a different head but also if the AN fitting is damaged that too can be switched out
This is the timing belt side fitting and is a tolorance pressed in fitting
This fitting replaces the stock thermosat housing
This is the timing belt side fitting once it was pressed in the head
Old Feb 25, 2012 | 08:47 PM
  #37
lillev23's Avatar
Wow I remeber your car when it was grafite grey and you had that mag feature. Didn't you have a dogbox in this car driving on the street? Definitely one of the sickest street talons of all time
Old Feb 25, 2012 | 08:56 PM
  #38
TALONGT's Avatar
Yes that was me and I'm hoping to still drive the car on the street with the auto Power windows, interior, glass, headlights etc
Old Feb 25, 2012 | 11:10 PM
  #39
gr8stevo's Avatar
8sec auto 1g/2g are old news lol
Old Feb 26, 2012 | 06:58 AM
  #40
TALONGT's Avatar
I know weak sause! Atleast I can still drive it on the street for fun
Old Mar 6, 2012 | 07:56 AM
  #41
TALONGT's Avatar
Here is a fixture we did up to allow us to drill out bearing for use with aluminum rods. For anyone that doesn't know you need to run a dowel in aluminum rods to keep the bearings from spinning.
Here is a stock 6 bolt rod that was machined flat
Then machined the rod out and pressed in a hardened insert for the drill to ride in
Here is the final version done and tested
Old Mar 13, 2012 | 12:55 PM
  #42
TALONGT's Avatar
Well I pulled the plug this week and parts are ordered things should start coming together soon
Want to say a big thank you to everyone including Myles at ER for a Honda guy your okay Jeff and Lucas and Arron at ER, Tony and his dad, Corey at Brake Man, Steve at SJM, Mike at ETS, Justin at Comp, and Kevin Kiggly, Will at Supertech, Ziggy at RTM and anyone I missed!
Old Mar 22, 2012 | 08:05 AM
  #43
TALONGT's Avatar
Came to a depressing realization that even though I started this project way over weight compared to the guys I'm racing against that between my cage and trans I added another 200lbs on to my car
Old Mar 28, 2012 | 08:30 PM
  #44
lillev23's Avatar
damn. You're definitely going to want to drop some weight out of that pig. A little off topic, but what were the specs on those OZ racing wheels that you had on the car when it was the graphite color?
Old Apr 1, 2012 | 09:10 AM
  #45
warp9's Avatar
Cool project! Whats the stall on that convertor? Its tough to go 8's and have the convertor like street duty. BR shootout this year?
