Daihatsu!!
Old Apr 25, 2004 | 10:19 PM
inwe_melwasul's Avatar
Question Daihatsu!!
Ok so i think daihatsu makes some cute looking cars but i know almost nothing about mechanics....so how does this engine look?
The JB-DET engine, designed exclusively for the Copen, generates sufficient torque from the low rev range. The driver feels the torque increase linearly from startup and the engine responds directly to pressure on the throttle pedal.
(1) Dual flow turbo
Two pipes are used to funnel the exhaust gas into the turbine, improving the boost efficiency in the low rev range, and delivering a powerful and high-torque run from the low to high rev ranges.
(2) Small diameter turbo
Small-diameter impellers are used for the turbine. By optimizing their size, a direct acceleration response is realized.
(3) Abradable seal structure
The compressor housing incorporates a resin material which minimizes the clearance between the compressing wheel and the case to further raise turbo-charging efficiency. Powerful torque from the low rev range drives the car with indefatigable acceleration.
note the awkward japanese to english translation
Old Apr 26, 2004 | 06:05 AM
WestSideBilly's Avatar
El Jefe
I think the translation of the turbo (#1) may be a bit off.
Old Apr 26, 2004 | 06:14 AM
hahaha, silly japanese... i only know about cars what tenky has tried to explain to me, i just know i like this car but have no idea how it would perform. Is this just a slow everyday car?
Old Apr 26, 2004 | 08:28 AM
tenkawa_akito's Avatar
number one sounds like it's using a twin scroll design to propell air over the turbine with more force causing faster spool up.
Old Apr 26, 2004 | 08:57 AM
El Jefe
That makes sense, Tenky. The literal translation sounds like a back pressure nightmare.
Old Apr 26, 2004 | 09:03 AM
El Jefe
The Copen's specs:
Front engine, rear drive, 660 cc I-4 Turbocharged, 64 HP, 81 lb-ft torque, 8500 RPM redline. 0-62 mph in ~9 seconds. Sells for about $23,000 in england.
Old Apr 26, 2004 | 10:04 AM
ok thanks guys!
Old Apr 26, 2004 | 10:10 AM
i love engrish!
Main Features
(1) A unique styling that pursues the pleasure of ownership
(2) An easy-to-operate active top (electrically operated folding roof)
(3) High performance that's a joy to handle
(4) Fully equipped to allow wide-ranging utility as a bread-and-butter car
(5) Hand-assembled at Daihatsu's Expert Center by a select group of craftsmen
(6) Safety features that support comfortable driving
active top huh?
Old Apr 26, 2004 | 12:15 PM
Originally posted by WestSideBilly
The Copen's specs:
am i reading that right 660cc? tyhat's less than a litre. engines shouldn't be that small!
Old Apr 26, 2004 | 12:42 PM
El Jefe
Yes, 660cc. I found one site that listed it as 3 Liters, but a 3 Liter turbo engine would hopefully have more than 64 HP.
The car is exceedingly small, similar in size to a Get Metro.
sdhotwn
Lancer Engine Tech
28
Sep 27, 2009 08:43 AM
04Evo8RS
Aug 15, 2006 05:04 PM
bobaab
11
May 3, 2004 05:30 PM
Ree
19
Feb 13, 2004 09:05 PM
shirokuma
Mar 22, 2003 02:08 AM
