Mid-Atlantic Region Includes DC, DE, MD, VA, WV.
Va Beach EVO's
Old Jun 8, 2011 | 04:16 PM
  #5761
oriley9959's Avatar
does anybody in virginia beach have valve stays for an x or some that will work on an x i dropped one and cant find it. thanks
Old Jun 8, 2011 | 04:36 PM
  #5762
asininedervish's Avatar
So has anyone ever had a wastegate get stuck open? I start up, sounds like a horrendous exhaust leak, and the dump is putting out a good steady flow of exhaust. This randomly happened 2 days after a track day.
Old Jun 8, 2011 | 04:45 PM
  #5763
BLKCarbonEVO's Avatar
External or internal?
Mikey
Old Jun 8, 2011 | 04:53 PM
  #5764
meat_EVO's Avatar
check your carter pin if you are eternally dumping a stock location wastegate. the arm could of simply popped off the wastegate flapper.
Old Jun 8, 2011 | 04:55 PM
  #5765
^ This
Old Jun 8, 2011 | 06:20 PM
  #5766
Internal on a HTA green. Arm is still on, but i cant manually move it at all. never tried before, so dunno if its even possible
Old Jun 8, 2011 | 06:26 PM
  #5767
EvoX2NR's Avatar
Originally Posted by Draven83
ive texted you a few times and no reply. let me know when ur free. you know i am daily after 12. lol
The last one I got was about white lightning...
I am off Friday... I will tune your car after you are done with work
Old Jun 8, 2011 | 06:37 PM
  #5768
It shouldn't move because it is under pressure. How much preload do you have on the wastegate? You may not have enough.
Mikey
Old Jun 8, 2011 | 06:44 PM
  #5769
HeatherificEvo's Avatar
I practiced changing my tire today...successfully I might add. One question: does anyone use the wheel locky thing? I am so afraid of losing the key so my gpa suggested replacing with a regular bolt. Advice? Also i found out BJ's in Virginia Beach has an air pump that is quite handy and anyone can use it. You dial in your poundage, and it will stop there automatically. Fun!
Old Jun 8, 2011 | 06:52 PM
  #5770
EvoX2NR's Avatar
I can give you 4 lug nuts if you want. I hate using locks because of an issue I once had where the key stripped...
Old Jun 8, 2011 | 07:02 PM
  #5771
That is so sweet of you, but I would insist on paying you the going rate for them. Also, is it reasonable to expect i can change my oil and fix that vacuum line being discussed in the general forums? Its an urgent message about possible leaks.
Old Jun 8, 2011 | 07:08 PM
  #5772
EvoX2NR's Avatar
Don't worry about the lugs... the stock ones don't do me any good since I can't use them with my rims.
The vaccuum line (for the fuel pressure regulator) I think you are talking about can be fixed with a zip tie in about 5 seconds.
Old Jun 8, 2011 | 07:15 PM
  #5773
Again so sweet...ill hit u up about those then. Poor college student haha. Maybe i can bring some cookies or sumpin? Also, first dumb question about said zip tie: cant this be purchased at the autozone place up on laskin? Or can any trash can tie do? I feel like a tard....
Old Jun 8, 2011 | 07:24 PM
  #5774
Skott2k's Avatar
If you mean trash can tie like a twisty one then no, its gotta be a zip tie that locks into place but pretty much any auto or hardware store sells them.
Old Jun 8, 2011 | 07:28 PM
  #5775
Invest in a bunch of zip ties they come in handy in a lot of cases. Evo is famous for vacuum leaks.
Mikey
