SS clutch cable install and restrictor removal help?
Anyone from around the richmond area that has done the SS clutch cable or restrictor removal if so I would like someone to help me do mine once I get the cable in wednesday would like to do it sometime early friday if its possible. Sir Lurks Alot if your going to be down friday it would be cool if you could help me I plan on going to the track again this friday night then head up to the new shortpump mall for that lancer/evo meeting they have up there every friday after I do a few runs see how much a improvement the new clutch, restrictor removal, and cable does.
Just did mine this past weekend.
I don't know how much of a help I could be to ya, especially considering I have a day job
I followed Timzcat's instructions on here under the "clutch fix" thread and didn't have any problems - other than dropping one of the screws down on the plastic air deflector under the car (that sucked getting that out, btw!).
Took me and my brother a couple hours, mainly because I spent an extra 30 getting the damn screw out.
One tip I can offer - the banjo bolt up by the master cylinder is easiest to get to if you lean over the car from the front - lean your left elbow just under the windshield wipers, and screw it in with your left hand. I got it the first try like this. It is, however, a ***** to get a 17mm closed-end wrench in there to tighten and loosen that bolt. I found that removing the top of the hose from the master cylinder's plastic reservoir over to the little thingamajobby on the firewall where the banjo bolt is, makes it a helluva-lot easier to get a wrench in there.
Rest of the stuff is on the website already. Some good info on here
PC325xi
Mar 24, 2009 11:20 PM
03SilvaEvo
12
Apr 9, 2007 10:27 PM
chinto
Jan 17, 2005 08:15 AM
JT-KGY
30
Dec 17, 2003 07:26 PM
