Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
Help... bosst is too low
Old Apr 28, 2007 | 11:11 PM
colo_evo's Avatar
I live in Colorado(5500 ft abvove sea level) and I just hooked a boost gauge to my car and it is boosting way low. I thought it would boost lower than stock because of the elevation, but not 6-8psi less...
Background:
Stock Evo VIII
32000 miles
First gear: 11 psi.
Second gear: 12-13.
third gear: 13, tapers to 11 at 6800rpms.
Im going to go try and tighen the intercooler pipes and borrow a friends boost gauge.
Old May 2, 2007 | 11:46 AM
DynoDude55's Avatar
Sounds like you have a boost leak or your Turbo is starting to go south on you. If you need so help with this hit me up.
Old May 2, 2007 | 11:47 AM
Assassin's Avatar
Sounds like you're runnin on waste gate pressure to me. Check all your boost lines to make sure everything's the way it's supposed to be?
Old May 2, 2007 | 11:50 AM
tweakdsm's Avatar
#1 do the boost leak test. IF not check all the vacum lines/clamps.
Old May 2, 2007 | 12:33 PM
Evo_SpeedKing's Avatar
you are on wastegate pressure. you either have a BIG leak or you installed it incorrectly. did you remove the boost pills?
Old May 6, 2007 | 08:19 PM
colo_evo's Avatar
I got a different boost gauge in there now and it holds about 17. I couldn't believe it, the boost gauge was off.
The funny thing is that i got the boost gauge from my buddy with an All-Trac(toyota's DSM). long story short... he blew a head gasket because he tuned for what he thought was 14 psi, when it was really about 19.
Thanks for the replys...
One more question: I just ran my car at the local track(Bandimere Speedway) and my best i trap was 95.6mph. Does this sound right for my car at this elevaton?
Has anybody reading this ran a stock evo8/9 at Bandimere? or at a similar elevation(5800+)?
Scott
Old May 6, 2007 | 08:53 PM
LancerevoIX2006's Avatar
Scott
95mph
wtf sumthing is rong how was ur launch!?
Old May 6, 2007 | 10:30 PM
colo_evo's Avatar
I know it isn't great, but i managed a 1.999.
TK40
Sep 2, 2010 03:12 PM
riceclown
32
Jun 16, 2008 08:56 PM
MitsuJDM
Jun 13, 2007 01:12 PM
93civEJ1
May 5, 2005 08:53 AM
evolutionist
Sep 20, 2003 05:01 AM
