Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
IN EVO Spotted Thread
Old Nov 11, 2009 | 06:18 AM
  #1771
bigwills_evo8's Avatar
ok so i need major help does anyone have or no whetre i can get another ecm besides the dealer i cant seem to find anyone that has one for sale that is what went bad on the evo
Old Nov 11, 2009 | 06:26 AM
  #1772
DrBump471's Avatar
^^Tried calling junkyards yet?
Old Nov 11, 2009 | 06:27 AM
  #1773
ktk's Avatar
ktk
Ouch If you can't track down a OEM ECM at a reasonable price, may I suggest upgrading to AEM standalone? Thats probably a good long term choice if you have to replace the ECM anyways....
Old Nov 11, 2009 | 06:38 AM
  #1774
ktk's Avatar
ktk
Originally Posted by SyZyGy1394
PICS NAOUGH!! I want to do ceramic coating, but I don't like the really shiny coatings. I've seen like a flat silver that looked similar to cast aluminum. Me rikey!
Ya I fail. Had it sitting in my living room for 2 weeks and I never took pics. I'll snap a few this weekend when I kut back to the shop.
It is a shiny black finish this time. My old setup had flat black ceramic which looked ok, but showed scratches and dings and wear and tear from messing around in the engine bay. The Pro-Kote place also had a "polished stainless look" ceramic finish that was nice too, but their "Black Satin" had the highest temperature resistance so I went with that.
Keep in mind that the material your header is made out of has a big impact on coatings. Thermal expansion of the header will cause ceramic coatings to crack if the coating is not thermally matched/good quality. And if you have a high dollar stainless header, then you don't even need ceramic coating at all. The heat transfer coefficient of stainless is like already around 80-90% lower (depending on alloy) than that of typical 1010 mild steel.
If any of you are planning on getting headers in the near future FYI the best alloys for headers are probably Stainless 304, 316L, 321, and 347. 304 is the most readily available (cheapest) and does a decent job, 316L has a much lower carbon content and will be better at resisting something called intergranular corrosion that occurs in stainless at high temperature (and weakens it over time). 321 and 347 grade stainless are probably your top tier choices, 321 is alloyed with Titanium and 347 with Columbium, these essentially eliminate the issue of intergranular corrosion almost completely (but they are the most money :P ) If you are cash money bawler, you can splurge on Titanium headers which are awesome but hard as hell to make.
Old Nov 11, 2009 | 12:20 PM
  #1775
yea i found one for 375 at a junk yard the aem one is 2k which isnt in the budget lol but thanx guys
Old Nov 11, 2009 | 01:05 PM
  #1776
DrBump471's Avatar
^^ Nice Work!
Old Nov 11, 2009 | 05:22 PM
  #1777
Routybouty's Avatar
Hey ktk, would that shop be willing to do a tranny rebuild similar to a shep?
Old Nov 11, 2009 | 05:24 PM
  #1778
ktk's Avatar
ktk
Nu, my guys don't do transmission internals. Your best bet there would be to go to Shep or Buscher or TRE. I've talked to John Shep he's a cool guy and very experienced with Evo trans, he's probably your best bet.
Update: Apparently we do have a guy who can do transmission rebuilds. I just found out myself. PM if you want info
Old Nov 11, 2009 | 07:18 PM
  #1779
shep is great why do u need it rebuilt id just have him look at it and re seal it thats what ive known alot of people to do and there evo has like 600 plus awhp
Old Nov 12, 2009 | 01:15 PM
  #1780
Routybouty's Avatar
My 5th has a syncro grind at high rpm. I just want to drop it off at a shop and have them send it to shep. I want it rebuilt with an evo 8 4th. I think the evo 9 4th-5th is too big of a ratio difference and it just tore up the syncro, but then again I'm not a tranny expert. Where would be a good place to do this? I'm thinking late winter/early spring I'll do it.
Old Nov 12, 2009 | 05:17 PM
  #1781
btownsoccer22's Avatar
yea my 5th grinds at high RPM's also, occasionally though not all the times.
Your only about a 3 hour drive away from Buschur/shep.... You could just drop it off
Old Nov 12, 2009 | 08:54 PM
  #1782
FathouseFab's Avatar
Shep will put the evo 8 3rd and 4th gear in it also.
Evo 9 1st gear
all second gears are the same
evo8 3rd and 4th
evo9 5th
Thats the trans in my car. Built by the best.
Fathouse
Old Nov 13, 2009 | 02:31 AM
  #1783
NickieBlaine's Avatar
jeremy i didnt get your message until i was going into work. i was asleep when you called, but ill get ahold of you tomorrow after i give SBR a call and hopefully get something figured out.
Old Nov 15, 2009 | 09:58 PM
  #1784
ktk's Avatar
ktk
Actually, yes! I just found out this weekend. PM me if u want infos....
Old Nov 16, 2009 | 06:47 AM
  #1785
if anyone knows of a stock shortblock anywhere let me know!
The 2.4 didnt last 200 miles before it spun a bearing, so i need something to put in there while SBR rebuilds/whatever they are going to do for me. And by the looks of things, it may be a while before i see that motor, esp if i have to get a lawyer involved, etc. So, if anyone knows of one for a decent price, let me know!
