May Service Packages: Clutches - Brakes - Timing belt/Chain & more!!!
From small jobs to big jobs, maintenance or performance. We can do it all!! Give us a call or stop by the shop for a quote today - Brake & Clutch Replacements, Timing Belt/60K Service, Injector Cleaning & Installation, Oil Changes/Fluid Flushes, Engine & Transmission rebuilds and more.
Visit our website: www.BoostinPerformance.com
CLUTCH REPLACEMENT PACKAGE:
We offer a wide variety of clutches. Purchase a clutch kit (single, twin, or triple disc) from us and schedule to have it installed and $AVE an additional 15% on the package! (parts & labor). Don't forget about a Drivetrain Fluid Flush, or inquire about a transmission rebuild.
We carry:
- Competition Clutch
- Quarter Master
- Exedy
- ACT
- Spec
- Trans Fluid – Red Line – AMSOIL - OEM Diqueen
- & much more
BRAKE PADS / ROTORS / STAINLESS BRAKE LINE SERVICE PACKAGE:
Brake replacement parts (front and/or rear brake pads, rotors, and stainless steel clutch lines). Purchase the entire package from us and $AVE and additional 10% (on parts and labor). Contact us for a quote today!
We carry:
- DBA
- Hawk
- Power Slot
- Stop Tech
- Project Mu
- Ferodo
- Brake lines – Russell – AGP & more
- Brake Fluid – Motul – Stop Tech – Super Blue Racing
OIL CHANGE / DRIVE TRAIN FLUSH PACKAGE
Pick one of the following packages, or have us perform all of these services at once.
- Oil Change using AMSOil or Valvoline VR1 Full Synthetic oil & new OEM oil filter
- Full Drive Train Fluid Flush (includes transmission, transfer case, rear end flush)
- Spark Plug Replacement using OEM or NGK plugs
- 32-point Full Vehicle Inspection
- Corner balancing/ Custom Race Alignment / Tire Rotation
TIMING BELT REPLACEMENT PACKAGE:
- Timing Belt(OEM & Gates)
- Timing Belt Tensioner & Pulley
- Balance Shaft belt & pulley
- Water Pump and Gasket
FUEL INJECTOR CLEANING SERVICE:
If you run E85 in your vehicle, we recommend that you clean your fuel injectors AT LEAST 2-3 times a year, or more often depending on how long you run your car on this fuel. Failure to do so will result in your injectors being clogged with debris, which can lead to engine failure. Include Injector Cleaning as part of your regular maintenance routine, and drop off or ship us your injectors. Typical turn around time for this service is 1 business day.
Berndog67
Aug 3, 2017 04:25 PM
Boostin Perform
Evo 'For Sale' Services
Jan 5, 2016 02:31 PM
Boostin Perform
Midwest Region
Jan 5, 2016 02:30 PM
Boostin Perform
EvoX 'For Sale' Services
Dec 15, 2015 09:51 AM
Massimo Power
Evo 'For Sale' Suspension / Brakes / Handling
18
Nov 7, 2008 07:37 AM
