- Display Model - BRIDE Gias II Kevlar Back - Low Max - $1300
- WEDSSPORT SA55M 19x10.5 +15mm (BBM Color) - 1 x Pair - $1000
- 9 WGA, FP 18psi WGA, EVO 9 J-Pipe, 84MM Intake, OEM FP adapter with Tovic gauge
- 800whp 9 Second Part Out! Buschur, AMS, FIC, STM, DI, Tial & More!
- Tons of Stock EVO 10 Parts, Door Panel Driveshaft Suspension Interior Exterior! MORE!
- Tons of Stock EVO 8/9 Parts, Door Panels Driveshafts Fender Interior! Exterior! MORE!
- Used AMS EVO 8/9 LICP and Stock Fitment Turbo Downpipe
- Helping Customer Part Out Evo X.. Cracked Pistons.. :( HIGH END AFTERMARKET!!!
- Custom intakes for FP turbos, walbros, Kinsler FPR, Defi EGT, Magnecore wires,
- WORK Emotion 11R-FT 18x9.5 +15mm offset + Hankook Tires
- ARC heat shield and spark plug cover
- FS: MT ET Slicks with Rota Slip Stream Rims(NY)
- Red Powdercoated EVO 9 Mivec Valve Cover
- FS: Buschur Racing Baffled Oil pan + Tomei crank scraper + OEM Oil pans
- Custom AMS Turbo Kit Parts, Small Koyo Radiator, Big Ball Bearing PTE 6765
- ToxicFab Stock Replacement manifold Coated!!!
- AMS Mitsubishi Lancer Evolution X MR/Ralliart Transmission Cooler Kit
- FS: OEM Alternator / Power Steering Pump / Starter / AC Compressor / Injectors / TB
- High End EVO X Aftermarket Part Out!! FP Red, Buschur FMIC, Exedy Twin, 700 Miles!!!!
- M.R Carbon Hood Scoop EVO X
- FS: FP3586 - Hossier QTP's - FIC 2150's - AEM EMS - Exedy Twin HD
- FS: USED Evo X Cosworth Cams!!!!
- EVO X Shortblock & Head For Sale!!!!
- Used 35r Turbo kit, Koyo Radiator, HKS DLI and MORE!!! CHEAP!!!!
- FS: 2006 Evo 9 MR Complete Longblock
- FS: 2006 Evo 9 MR 6 Speed Transmission & ACD Transfer Case
- Insane Speed Built: 2.4L 4G64 Based Stroker
- FS: Evo 8/9 ID 2000 Injectors & FP5R Cams
- AEM EMS for evo 8.
- HKS SSQV Version 3 Blow off valves
- AMS Small/Drag Radiator Kit w/ -16 in/out and Flexalite Fan
- AMS EVO 4-9 Rally Brake Kit, Refurbished
- EVO 8 9 Wilwood Brake Kits that need a little work!
- 2 GT42R 1.15 T4 Divided Turbine Housings, Cheap
- EVO X and EVO 8/9 BOVs
- Used AMS Ralliart 3" Twin Tip Exhaust
- Used AMS/Wilwood Mitsubishi Lancer Ralliart Big Front Brake Kit
- Used JIC FLT-RS Racing Spec Coilover Kit, EVO 7/8/9
- Comp Cams FS
- AMS EVO X Black and Silver cold air intake extension kits, $125 shipped each!
- EVO X Bilsteins with GTWORX Tarmac Springs
- FS: Spark Tech EVO 8 COP with CDI System PRO
- NYC: Enkei NT03 +M W/ Nitto Invo 255/35/18
- Aftermarket EVO 8/9 LICP, Steel
- EVO 8/9 3" Downpipe w/ Test pipe built in
- Injen EVO 8/9 UICP Kit
- AMS EVO 8/9 cat-back muffler rear section
- Exedy Triple HD push style, complete, used.
- ARC Evo X FMIC & Rebuilt FP RED Evo 8/9!!!
- Mishimoto EVO 4-9 Aluminum Radiator w/ -16 Fittings welded on, CHEAP
- USED EVO X FpRED --- Cheap!!
- FS: Greddy, Sparktech, Endless, AEM, Boomba...etc. LAS VEGAS
- FS: Performance & Stock parts(NY)
- Magnus V5 Intake Manifold NEW 750.00 + more
- Stoptech ST-22 Rear Big Brake Kit
- Whole bunch of PTE, Tial, and HKS turbine housings CHEAP!!
- HUGE Precision 6765 Ball Bearing CEA Turbo
- FS: Precision 62/62 Turbocharger, 1000cc Precision Fuel Injectors, Boost Controller
- FS: ID2000 Injectors(NY)
- FS: Evo X Muse 3" intake
- FS: Stock Rad and Condensor(NY)
- Used AMS Ralliart FMIC
- Stance EVO 8/9 GR+ Coilovers Springs Suspension
- FS: QuarterMaster Twin disk clutch kit(NY)
- Used Kelford EVO X "B" Cams
- Used 6 speed, ACD computer, 3" HKS Hyper cat back
- Used EVO X Turbo w/ Lines, Chipped exhaust wheel
- Exedy MM023HBMC EVO 7 8 9 Triple Carbon Clutch CHEAP
- FS: Mishimoto Radiator Hose Kit (Blue)
- Stock and aftermarket parts
- 4G63 and 4G64 Cranks for Sale!! 88mm and 100mm
- Mitsubishi BBY Evolution 8 Wing. Mint Condition! **Must Sell**
- Stock Mitsubishi Evolution X MR TD05 Turbo 4B11
- HKS Kansai CF Air Box EVO 7, 8, 9 **Great Condition**
- Top Level Interior/Exterior part out
- Tomei 272 cams evo 9 $400
- AMS 6765 Turbo Kit
- ETS 6262 82 Turbo kit $3000
- 2008 Evo X GSR Partout.. 21k Miles on EVERYTHING!!!!
- 4G69 Head & Intake Manifold - $175 OBO
- K&N Typhoon Intake Kit for the EVO 8/9
- EVO 8/9 Driveshaft
- EVO 8/9 Sunroof Assembly
- EVO 8, 9 and 10 Driver's Side Rear Door
- Used, EVO 10 Dashboard
- Sparktech CDI & PPI, ported, machined & Swain coated E/M!
- FS: Performance & Stock Parts(NY)
- Hawk "Blue" pads front & rear, like new!
- FP Black turbo, ported & silver coated, polished comp. cover. Like new!!
- EVO 8 seats for sale(1 bolster loose) 550.00 LOCAL PICKUP ONLY
- Stock EVO X Brake Calipers, Great shape
- EVODYNAMICS Shop Garage Sale!
- A ton of methanol injection parts!!
- Bad Bish/EVO8 seats/interior for sale.
- EVO X Parts for sale
- FS; EVO 8 turbo w/ 10.5 hotside
- Alkycontrol Methanol Injection Pump
- Red Fidanza Cam Gears, Slightly Toasted
- Air/Water intercooler water pump
- Custom AMS EVO 8/9 5 spd. Motor Mounts
- HTA3586 Equal Length Turbo Kit (Used Turbo, New Kit)
- FS: Shearer, GSC, Aeromotive, AEM, Beatrush, HKS, PLX,OEM Parts Galore Priced To Sell
- EVO 8 and 9 cams CHEAP. New and Used. JUN HKS Tomei GSC Kelford
- FS: Evo 8 Built Part Out(NY)
- AMS 3" EVO X Test Pipe on eBay Cheap!
- FS: MR SE BBS wheels/tires ,, Rear diff ,, and more,,
- Random parts at blow-out prices!!!
- F/S: Like New FIC 1100cc High Impedance Fuel Injectors for Evo 8 & 9 $350 Shipped
- FS: USED SSR Type F 18x9.5 5x114.3 +22 with Nitto NT-05
- Complete Engine / Tranny / ACD T-CASE
- FS: Radiators(Koyo & Stock), Buschur UICP, AMS Lower ICP, Samco, STM Intake
- Voltex - Damaged Goods Sale: GT Hood and Rear Diffuser for Evo 8/9
- SSP 500HP Clutches for EVO MR.... 250 Miles!!!
- COBB Tuning Garage Sale! Oct 16th!
- ACT Streetlite Flywheel / Resurfaced $149.99 Shipped
- JDM HEADLIGHTS NO WAIT IN STOCK USED CLEARANCE SALE @ ViViD Racing!!!
- Tubular Stock Frame Exhaust Manifold for Evo 8 & 9 $499.99 Shipped
- Used AMS EVO X Downpipe
- EVO 8, blocks.. head... more!
- FS: Blemished Fortune Titanium Strut Bar
- Advans- lots- for sale!
- *** EVO X TURBO - Intake - HKS AIR FILTER *** GARY@MELLON TUNING
- Used AMS Silver Race Fuel Rail w/ Fittings - $100 shipped
- Bad Bish's, Apexi N1's and rear sway bar.
- OEM EVO X Parts, Turbo, Manifold, Exhaust, Swaybars, Brake Pads, Calipers, AC Parts..
- Used EVO X FP Red Turbo on eBay, Cheap!
- ****EVO X OEM TURBO For SALE *****Low mileage
- STM used parts!! Stock turbo, 02 housings, rods/pistions, zaklee
- AMS VSR Intake Manifold, Used on eBay!
- FS: Evo 8---> 11 second package!!
- Tubular Stock Frame Exhaust Manifold for Evo 8 & 9 $600 Shipped
- Badbish, NT03+M's for sale
- Buschur, Nesei, Exedy, Perrin and More!!
- MAP 3.5" Evo X Intercooler / Priced to Move!
- JIC Magic Coilovers Evo 8 Mitsubishi Lancer Evolution
- FS: Evo 9 Turbine Housing 10.5cm $100 OBO
- 2 Sets of Precision Turbo 1000cc Fuel Injectors
- Evo X FpRED -- Evo 8/9 Tomei turbo kit -- and more!!
- FS 2 stock Tcase lsds
- FS: Black Front Avid Motor Mount. AMS Upper and Lower Stainless Clutch line
- fs 03 rebuilt tranmission low miles
- Nissan GTR R34 Front and Rear Brembo BBK 4pot/2pot
- Forge RS BOV
- Carbontrix Front Bumper
- Advan A048 Spare Tires - Never Used 245/40/17 & 265/35/18
- ETS T3 headers, dp, o2, tial 38
- STM 3" Intake Pipe kit!
- FP BLACK Ported FOR SALE 150 miles on it
- DW 800cc injectors / Invidia o2 housing
- Gary@MellonTuning - Used parts Sale -FpBlack-Ams IC-02dump-PPI
- Some CT9A Goodies for you!
- Accufab Mustang Throttle Body with TPS and Pigtail
- Spec-Ops Motorsports Used Parts F/S thread........
- For Sale: Used Mishimoto Aluminum Radiator for Evo 10
- AWD Motorsports.. Get all your 4g64 Blocks & Cranks Here!!
- Several used parts, check this out!!
- EVO X fpRED up for grabs!!
- Intercooler LICP, UICP in gold reflective foil & Manifold Heat Shield
- EvoDynamics Shop Cleanup Garage sale!!
- *BRAND NEW* - Evo X OEM Piston & Rod Sets
- *FOR SALE* - Evo 8/9 Energy Suspension Rear Differential / Mustache Bar Bushing Set
- FS: Evo 9 bov(2) NY
- FS: ETS 3inch IC/ IC Piping/ Guage pod/ Quaife(NY)
- Evo X Downpipe - Vent To Atmosphere
- FS: HKS GT3240R Kit BARELY USED!!
- NEW! ETS Evo 8/9 42R V-band Manifold w/ 44mm Wastegate - $900.00
- NEW!! ETS EVO 8/9 Front Facing Race Manifold (Wstegate On A/C and P/S Side) - $750.00
- FS: Performance parts & Stock Parts(NY)
- Stock Evo X parts
- FS: Stock Parts(NY)
- FS: Stock & Performance Parts(NY)
- Ross EVO drop in replacement pistons, 2.0 Std. 8.8:1
- AMS Downpipe and Adaptor to connect to stock fitment exhaust, OEM Exhaust
- ACT PP, CM flywheel, new disc, Evo 8/9
- 61mm turbo kit (ETS) Evo 8/9
- HKS EVO 8 280 Cams Cheap!
- FS: PTE 6262 off of our shop car
- evo8 RS partout engine/tranny/TC
- FS: FP Green, Evo 9 front brake calipers
- OEM Silver EVO 8 9 Wing, CHEAP
- Eagle 94mm 7 Bolt 4G63 Crank, Needs Work!
- K1 94mm 7 Bolt 4G63 Crank, Needs Work!
- AEM EVO 8 EMS, Cheap
- FS: Hoosier QTP's on Rota slipstreams
- FS: Used Evo 9 Turbocharger
- Used 04 5speed Shep Transmission
- 1 Black AMS EVO X UICP and 1 Silver AMS EVO X UICP, CHEAP!
- F/s evo 8 9 left and right headlight ballast
- F/s 2005 evo 8 9 ssl front leather seats ssl
- 2004 wrecked evo part out !
- 7 Bolt Mitsubishi 4G64 100mm Crank, Machined
- F/s 2006 mr evo 9 6 spped tranny
- 4 Used Hankook Ventus Z214 Track DOT Tires 275/35ZR18
- Ported and Black coated 10.5!
- Advan Racing - RS 18x9.0 +29 Dark Gunmetallic
- OEM EVO 8/9 Rocker Arms - $150 a set!
- Stock Evo 9 Turbo 40K miles
- FS: FP Green Turbo Kit(NY)
- Advan Racing - RZ 18x9.0 +25 Bronze
- For Sale: HKS DL II
- FS: Quarter Master Twin disk kit/ T4 Shearer manifold)NY)
- 30-1313 AEM EMS Evo VIII
- Lots of stuff!! cbrd parts...
- Tial Q Recirculated Kit w/ AMS UICP
- APM EVO 8/9 60-1 Turbo Kit, Complete w/ Tubular Manifold - $1500
- EVO 8/9 Battery Relocation Kit w/Moroso Box - $100
- FS. 4g64 7bolt crank
- FS. 06 6speed mr tranny, 05 Acd tcase, IX turbo, EvoIX Tcase LSD
- EVO IX Recaro Black leather interior
- Volk Racing TE37 18x9.5 +22 w/ Falken RT615 - $2,900.00 Picked Up!
- Polished AMS VSR Intake Manifold EVO 8-9 Cheap!
- FULLY BUILT INC'S Clearance Sale!
- FS: Recaro SPG XL in Red
- Used AMS EVO X Downpipe... CHEAP!!
- FS: Exedy Twin Disk Evo 8/9
- AMS 3" catback exhaust - Evo 8 / 9
- APR Evo 9 Lip & APR front splitter - carbon
- Fs/ evo 8 calipers all 4 brembo calipers !!!!!!!
- Parting out 2003 evo8 eveything must go whole car !!!!
- Quaife LSD
- Record Breaking BBK FULL For Sale.. Custom Ported!!
- Injected Performance Warehouse Clearance (New Products, Used Pricing)
- New JDM Evolution VII Rear Badge
- Full Set of OEM EVO X Doors, Silver, Perfect Shape, $300 ea door or $1000 for the set
- Wtb gg oem wingless trunk or any color !
- Set of STATUS Race Seats on eBay, Black/Kevlar, NEW and Very Nice!
- FP HTA 88 Tubular Top Mount Turbo Kit complete $2,500
- Used: 5!!! Advan RCII BRONZE
- Black AMS Mitsubishi Evolution 8 9 EVO Valve Cover Insert on eBay
- Sweet Stri Animated Gauge Display!! Great for the show/bed room!!
- precision injectors 1600 Cheap
- FS: Evo Oliver Connecting Rods
- Over 50 EVO 8/9 Performance Parts (TURBO KIT, AEM EMS, INTERCOOLER, EXHAUST'S, MORE)
- FS: Seibon CF Roof EVO 8/9 (Brand New)
- FS: Stock and Performance parts(NY)
- Used Full Blown Dual Pump Hanger 03 + Mitsubishi Evo 8 & 9
- AMS EVO 8 CNC Cylinder Head *Used* $1700
- Parting out PERFECT Evo 9 longblock...only 54k miles!!!
- FS: Stock Evo parts(NY)
- For sale fp white turbo nice low miles
- 2006 evo 9 blow off valve nice low miles
- Manual boost controller
- Fs/ hks blow off valve nice
- Universal Carbon Fiber Air/Coolant Catch Can Reservoir
- Stock evo 8 turbo for sale
- 2003 evo 8 complete car part out whole car
- Evo 8,9 starter, power steering pump, ac compressor,intake mani
- 2004 evo 8 factory oem infinity sub
