Ecuflash tuning basics......
Old Jul 30, 2006 | 11:44 PM
kf6ytc's Avatar
I have a few basic questions....
The 'mail-in' flashes that some vendors are offering;
What is the method of increased power delivery? Leaning out? Timing advance? Both?
What is the tipicial af/r's that are able to be had on the evo using 91 octane and still remain safe? Obvously this will change due to a hundred factors, but what is a good general rule of thumb?
How is everyone tuning your timing? My understanding is the only true way to tune a ignition map of a car is to use a dyno, advance until you make no more power and your done. Is everyone here just advancing until they see knock count and then backing off a little? is this safe?
My plans on playing with the tune on my car......
Make 2-3 pulls in 3rd gear, loging wideband af/r and knock count... Lean the car out to a 10.9 from 3000-5000 and 10.5 from 5000-8000 .. Do a couple more pulls to ensure accurate target af/r and no knock. Advance timing until i start seeing small knock counts (1-5) then retard timing 1-2 degrees or until i see no knock count.
Is this a good way to start? Am i on the right track? Please advise
Thanks for your time,
TJ
Old Jul 31, 2006 | 01:21 AM
mchuang's Avatar
TJ
Well I wouldnt say timing advance since it is a pretty crappy timing map that you get on a mail in flash, but removing boost taper for one and also someone leaning out..but normally as you boost more it will lean out..get a wideband and a logger and add timing until you see some knock count then back it out. Also you state you will lean to 10.9. I would say from 4000 on up you can lean to 10.9 if you would like. Still very conservative.
Old Jul 31, 2006 | 03:56 AM
kf6ytc's Avatar
Still didn't answer much of my questions........ So your saying a mail-in flash has the same (or less) timing than stock?
I understand you can advance until u see knock and back it out, but that's really not the right way. The right way would be advance timing until you make no additional power...... But that's almost impossable to do on the street.
Old Jul 31, 2006 | 04:07 AM
Magnumpsi's Avatar
That would be the right way to do it on a dyno in real time, but being how that cannot happen the right way would be to advance untill the ecu appears to see detonation and then, take it down a little.
Mitch Mckee
Old Jul 31, 2006 | 06:25 AM
MalibuJack's Avatar
Typical base flash:
Raise Rev Limit to a value you want
Set standing rev limit to a value you want
Set boost cut timer to some high value
Set fuel cut value as high as possible
In some cases increase boost value to hit about 20-21psi
Depending on mods
Lean out fuel from 9:0 or richer to 10:0-10.5
Some portions of the map can get a bit more timing..
Old Jul 31, 2006 | 12:35 PM
JohnBradley's Avatar
The few that I have seen actually advance timing alot in most of the map (8-10 degrees over stock in 120% and higher). Most of the target AFR's appear to be leaned one full point map to map, but since I havent logged a bone stock car I cant tell you what it actually equalled out to IRL.
Old Jul 31, 2006 | 12:52 PM
mannymartinez's Avatar
Originally Posted by MalibuJack
Typical base flash:
Depending on mods
jack this is something you recomend everyone to do as a base flash to work from first?
thanks
Old Jul 31, 2006 | 01:48 PM
MalibuJack's Avatar
If you have a wideband yes.. But generally the maps are so rich, that you can remove about 1 point of fuel from the 9:0 and richer portion of the map at high RPM if you set your boost for about 20psi.. That alone should pick up 20-30 hp and still be a safe tune. As you play with different boost settings, and AFR's, you affect the timing you can use, and vice versa...
Touching timing is a little different, but there are areas that can be worked on a little at a time.. You can also get another degree of timing upstairs and at peak boost, but that is more subjective and doesn't always go clean (you might get a little knock in some areas depending on your car)
Old Jul 31, 2006 | 02:03 PM
CAD EVO's Avatar
like this? sorry for the clarity, i basically mad all the 9:0 , 10:0 and left all the 8:0 alone.
Old Jul 31, 2006 | 02:42 PM
MalibuJack's Avatar
You can lean out the 8.0's also.. But depending on the boost levels you may not get into those cells..
Old Jul 31, 2006 | 02:44 PM
hondafan's Avatar
can someone explain to me the easiest way to determine what %load cell you're operating in for fuel and timing. i'm a little new to tuning by a load % vs. rpm, i come from the honda world where i'd tune a psi vs. rpm based map due to the ECU using a map sensor instead of MAF sensor. someone please enlighten me. i installed a base flash from al, but would like to fine tune it a little more.
Old Jul 31, 2006 | 02:47 PM
ShiftySVT's Avatar
Typical base flash:
Depending on mods
So what exactly is the function of the boost cut timer and fuel cut value? What causes them to cut? For my IX, I only see a setting for a "boost delay timer," but absolutely nothing that relates to a "fuel cut."
Old Jul 31, 2006 | 04:31 PM
MalibuJack's Avatar
Okay, the fuel cut value is the (boost/Load) threshold it must exceed before it will attempt to cut fuel, the timer is the duration of time it can exceed the threshold before it cuts.. Setting both of those parameters really high means it will basically eliminate it.
Old Jul 31, 2006 | 04:33 PM
MalibuJack's Avatar
Sorry, the fuel cut table is called "Boost Limit"
Old Jul 31, 2006 | 04:46 PM
Ludikraut's Avatar
Log a run and look at the timing vs. RPM values. Assuming no knock, this will give you the Load cells that you are hitting in the high octane timing map. You should be hitting the same load (%) in your high octane fuel map.
l8r)
