how to make more rich or more lean
Old Sep 17, 2006 | 06:58 PM
mlancerevo8's Avatar
?? on the ecuflash what is the formula to lean out the rpms... is it to add more or subtract more from the table ???
Old Sep 17, 2006 | 07:01 PM
hondafan's Avatar
adding will lean, decreasing will richen. example, 12.0 down to 11.0 will richen. 10.0 up to 12.0 will lean. good luck!
Old Sep 17, 2006 | 07:02 PM
occultworks's Avatar
Just like afr's, the bigger the number the leaner it is.
Old Sep 17, 2006 | 07:22 PM
thanks nother ??? which way do i need to go if im running too rich with 21psi manuel boost controled... on the high n low load settings??
Old Sep 17, 2006 | 08:26 PM
hondafan's Avatar
Originally Posted by mlancerevo8
thanks nother ??? ??
what does this mean?
Old Sep 17, 2006 | 09:17 PM
ScrappyJack's Avatar
Danger, Will Robinson! Danger!
1. How do you know if you are running "too rich?"
2. Familiarize yourself with the basic concepts of air-fuel ratios before moving on.
A basic user guide to ECUFlash has been posted that I think you will find very helpful.
Old Sep 18, 2006 | 08:19 PM
does this look right with my mods... for openloop loads??
load #1 load #2
86.875 - 500 86.9 -500
88.125 -1000 97.5 -1000
93.75 - 1500 98.8 -1500
105 - 2000 105 -2000
115 - 2500 113.8 -2500
113.75 - 3000 115 -3000
97.5 - 3500 100 -3500
76.875 - 4000 97.5 -4000
75.625 - 4250 76.9 -4250
75.625 - 4500 75.6 -4500
74.375 - 4750 74.4 -4750
60 - 5000 60 - 5000
55 - 5250 55 -5250
50.625 - 5500 50.6 -5500
41.25 - 5750 41.2 -5750
0 - 6000 0 -6000
Old Sep 18, 2006 | 08:31 PM
Doogie Howser's Avatar
+1
Spend the time at least on the tutorial, and search the forums and might be a good idea to check out AMS tuning tips sticky on their subforum of evom.
Cmeix
15
Apr 19, 2017 11:08 PM
revvin9k
Nov 6, 2009 12:35 PM
Boosted GP
Sep 22, 2009 08:22 AM
JDM_EVOVIII
37
Dec 25, 2004 04:29 PM
vietxscapeD
Lancer Troubleshooting
Feb 18, 2004 03:01 PM
