Heading to dealer, got questions...
Old Oct 10, 2006 | 02:30 AM
bboypuertoroc's Avatar
Veteran: Army
I'm heading in to the dealer on Wed to get my ACD checked out since all 3 lights came on yesterday. Question is, when they plug in the MUT tool to check, will they need to access the ECU itself or is the ACD seperate from that? If they need to access it, since my ECU is locked, how do I get it back to a stock flash? Will someone elses stock IX GSR flash work or am I SOL? If it can work, anyone got one I can "have"? Thanks for any help.
Tony (REALLY needs to learn ECU-type stuff)
Old Oct 10, 2006 | 11:22 AM
PessimiStick's Avatar
If you want to flash back to stock you will probably need to use MJ's unlocker tool to grab the immobilizer code off your current ROM, otherwise you won't be able to start the car with your copied stock flash.
Old Oct 10, 2006 | 11:43 AM
RazorLab's Avatar
The ACD is a seperate ECU located behind and to the right of the glove box.
Old Oct 10, 2006 | 11:44 AM
MalibuJack's Avatar
As long as they don't intend to reflash the ECU it won't be a problem.. the ACD adjustment is done with the MUT tool and it should be able to communicate with the ECU to do that stuff.. The only time you would need to be concerned is if they needed to reflash the ECU for any reason.
Old Oct 10, 2006 | 11:49 AM
RazorLab's Avatar
Jack,
This reminds me, is there a way to log the telemetry from the ACD via something like your logger or evoscan?
Old Oct 10, 2006 | 11:55 AM
MalibuJack's Avatar
Although I haven't seen any way to do it, I'm fairly certain you can test the EBD sensors which are 2 axis G-Force sensors, but I haven't done much research on it.
Old Oct 10, 2006 | 12:38 PM
Veteran: Army
So it would be a good idea to unlock and go back to stock beforehand. Would I be able to save my Dynoflash map and reload it after they're done?
Alright, DL'd the unlocker tool. When I opened up ECUFlash (I have 1.28) it gave me this message...
[22:09:14.828] Version 1.28.716
[22:09:14.843] 8 memory models read.
[22:09:15.093] 71 ROM metadata models read.
[22:09:15.093] checksum module "subarudbw" loaded.
[22:09:15.093] flashing tool "wrx02" loaded.
[22:09:15.093] flashing tool "wrx04" loaded.
[22:09:15.093] flashing tool "sti04" loaded.
[22:09:15.093] flashing tool "sti05" loaded.
[22:09:15.093] flashing tool "mitsukernel" loaded.
[22:09:15.093] flashing tool "mitsukernelocp" loaded.
[22:09:15.093] flashing tool "mitsubootloader" loaded.
[22:09:15.093] error loading FTD2XX.DLL
What's the error all about?
Old Oct 10, 2006 | 12:56 PM
MalibuJack's Avatar
Did you plug in the cable BEFORE you tried to run ECUFlash? You have to install the drivers, the error means the driver isn't installed (or you haven't plugged the cable in for the first time)
Old Oct 11, 2006 | 09:52 AM
Veteran: Army
Alright, I pulled the map from my ECU (and noticed some things were forgotten)... if I modify anything on the map and load it back to the ECU, will it still remain locked?
Old Oct 11, 2006 | 10:04 AM
JeffR116's Avatar
G-force meter sensor logging should be coming soon in EvoScan.
Old Oct 11, 2006 | 10:45 AM
Veteran: Army
I'm trying to find the immobilizer code so I can us another stock IX's map, but I don't know where the hell it is. I switched the user level to developer but still don't see it. Where is it?
*EDIT* N/M, found it.
Old Oct 11, 2006 | 10:49 AM
RazorLab's Avatar
Make sure you are using the newest version of EcuFlash and also you need to restart the app everytime you change the user level.
98autogstspyder
657
Apr 27, 2022 01:48 PM
tscompusa
Dec 7, 2016 03:31 PM
btownevo
Jun 27, 2010 10:35 PM
StevX
Oct 1, 2008 09:37 PM
mooreboost
25
May 14, 2005 03:52 PM
