Different wheel sizes?
Old Jun 8, 2007 | 11:17 PM
evodrivesme's Avatar
I bought a set of volk wheels that have 2 that are 17x8 and 2 that are 17x9 this was an accident of course but can u run this kind of setup on an evo, or is it bad for the diff and tranny or such things?
Old Jun 8, 2007 | 11:41 PM
Frenchy4g63's Avatar
As long as the tires are the same diameter it's fine.
It's a pretty popular setup to run wider wheels and tires in the front of the Evo in Japan.
It will mess with the diff if they are off.
Old Jun 9, 2007 | 06:04 AM
so what would be a good tire size to go with for these wheels?
Old Jun 9, 2007 | 06:17 AM
diablo2184's Avatar
i would say 245 or 255 depending on the brand of the tire.......
Old Jun 9, 2007 | 07:18 AM
and put the wider wheels on the front? i dont know a lot about wheels and tires ahaha. so i can run like a 245/40/17 or something on both of these wheels even though ones a 17x9 and the other is 17x8
Old Jun 9, 2007 | 10:10 AM
xX v0oDo0 Xx's Avatar
I have a hard time believing that, because the wheel weights will be different...I've only heard of using different offsets, but what the hell do I know?...I say sel off the set and buy something else...
Old Jun 9, 2007 | 11:06 AM
tlclee's Avatar
You can run a stagger size with the wider wheel in the front. The only thing you need to make sure is to run the same size and brand tires. With a stagger setup, you will be able to reduce understeer. However, the major draw back is not being able to rotate the tires. Most track junkie runs a 9.5 - 10" in front and 9 in the rear.
Tom
Old Jun 9, 2007 | 11:26 AM
atombomb33's Avatar
EvoM Community Team
But, you won't be able to rotate your tires properly without having the tires taken off and remounted on the rims. Could be a total pain in the *** every 5K miles...
Old Jun 9, 2007 | 05:18 PM
ya i can remount them no problem lol and the car isnt going to be out a lot mostly just on the track.
ok so let me get this right you can run a 255/40/17 or something on 8 and 9 inch wheels?
Old Jun 10, 2007 | 03:22 PM
tlclee's Avatar
Yes, you can run 255 on both. Just keep in mind you tend to stress the sidewall if you take them out too many times.
Tom
Old Jun 10, 2007 | 04:36 PM
ok so i will just order 255, will i need to roll my fenders after this and will i need some type of spacers?
jrod0187
For Sale - Wheels / Tires
10
Dec 27, 2012 10:41 AM
NickieBlaine
10
Jul 14, 2010 03:14 PM
PoloTurbo
Apr 9, 2010 03:16 PM
hamflex
Jul 2, 2008 05:41 AM
evosr2bnvd
14
Mar 1, 2007 09:22 PM
