No immobilizer code
Old Nov 21, 2008 | 09:31 PM
SiC's Avatar
SiC
No immobilizer code
I just confirmed that there is no immobilizer code within the EvoX ROM. I took my friend's ROM image and flashed it to mine, the car started up with no problems. I can only think that the EvoX may have a secondary ROM within the ECU that stores the immobilizer code
My friend also did a hex compare between 2 stock roms and the hexes showed to be exactly the same so I'm sure I wasn't just being "lucky".
Old Nov 21, 2008 | 09:33 PM
Chabada15's Avatar
good info
Old Nov 21, 2008 | 10:42 PM
Rguy's Avatar
Excellent info...
Old Nov 21, 2008 | 11:46 PM
STi2EvoX's Avatar
So, how exactly does the immobilizer code work then, because I remember someone having an issue where they tried to reflash their ecu with a very early version of open ecu and it wouldn't work because there was an immobilizer code issue. If I wanted to buy a second ecu to have as a backup (assuming that mitsu can in fact see flash counts on an ecu to determine if the ecu has been tuned or not) for warranty purposes, I know that the immobilizer code for the ignition system would have to be transfered over somehow. Any info on how to do this? Can you locate where this secondary rom within the ecu is and how to flash that image onto another ecu? Thanks.
Old Nov 22, 2008 | 06:26 AM
Messidona's Avatar
this is good information because i was about to send my ecu to flash and i was bit worried about the immboliser not working when i start back the car.
Old Nov 23, 2008 | 02:30 AM
Deepseadiver's Avatar
very interesting!
Old Jan 12, 2016 | 12:43 AM
Wanchai Panpron's Avatar
Lancer 09 is same.
My car was flash other Rom without reading stock Rom.
I think Immo code is in another ECU , will be ETECH that control all eclectic in car.
Thank for info.
Old Jan 13, 2016 | 10:40 AM
jakgal04's Avatar
For those curious, I replaced my ETACS-ECU and didn't need to reprogram the immobilizer. So its either in a separate portion of the ECU or another module somewhere.
Old Jan 17, 2016 | 11:08 PM
There are not in ECU(ECM) and ETACS-ECU
Where is it ???
Old Jan 19, 2016 | 08:03 AM
jakgal04's Avatar
Where is it ???
I have no idea lol, definitely not the ETACS though
SsZERO
Mar 15, 2019 01:40 PM
nuk1ear
Nov 27, 2016 05:13 PM
Raceghost
Aug 3, 2016 09:01 AM
Cbr1000love
Jan 30, 2016 05:27 PM
Dnasario
Jan 16, 2016 08:52 AM
