Can the Cobb AP?
Can the Cobb AP?
For Rob@Cobb or anyone who actually OWNS an AP for the X please tell me if I (MYSELF) can use the Access Port to:
1. Adjust open loop Fuel tables
2. Adjust timing tables?
3. Adjust tip-in enrichment?
4. Adjust global injector scaling?
5. Adjust injector dead time?
6. Adjust BCS duty cycles (to change boost levels)?
7. Adjust idle rpm?
8. Adjust rev limit?
9. Adjust launch limit?
10. Log knock?
11. Clear DTC's?
12. Export logged parameters to excel or external format?
13. Log my Wb02 through the AP as well?
14. Surf the web
kidding
I am trying to decide between the AP and EcuFlash and this info would be really helpful.
7. Adjust idle rpm?
10. Log knock?
11. Clear DTC's?
14. Surf the web
kiddingI am trying to decide between the AP and EcuFlash and this info would be really helpful.
i have asked those questions before too and no clear answer yet.. i need to know if you can make those changes WITH the handheld.. i know that w/ the pc you will but i want to know if you can do it on the spot
1. Adjust open loop Fuel tablesDon't know
2. Adjust timing tables?Don't know, suppose to be able to
3. Adjust tip-in enrichment?Don't know
4. Adjust global injector scaling?Don't know
5. Adjust injector dead time?Don't know
6. Adjust BCS duty cycles (to change boost levels)?Suppose to be able to
7. Adjust idle rpm?I was told by Cobb yes
8. Adjust rev limit?Told by Cobb yes
9. Adjust launch limit? Don't know have not ask.
10. Log knock?Yes
11. Clear DTC's?If this is codes, then yes
12. Export logged parameters to excel or external format?I think is also yes
13. Log my Wb02 through the AP as well?I dont think so.
14. Surf the web
kiddingYesssss, lol
Most of what you want has to be done with the tunning software. The logging is done with the AP itself, and you get it in a number and tables format from what i have read and you can export it to excel and even make charts i hear(from another member).
Hofully Rob will chime in.
10. Log knock?Yes
14. Surf the web
kiddingYesssss, lol Most of what you want has to be done with the tunning software. The logging is done with the AP itself, and you get it in a number and tables format from what i have read and you can export it to excel and even make charts i hear(from another member).
7. Adjust idle rpm?
10. Log knock?
11. Clear DTC's?
14. Surf the web
kidding
7. Adjust idle rpm?
10. Log knock?
11. Clear DTC's?
14. Surf the web
7. Adjust idle rpm?
10. Log knock?
11. Clear DTC's?
14. Surf the web
kidding
7. Adjust idle rpm?
10. Log knock?
11. Clear DTC's?
14. Surf the web
10,11,12 you can currently do with the AP unit.
I think one of the Pro tuners has to chime in here. You can not self tune with it at this time, so just AP owners probably would not the extent of its capabilities. It is suppose to be as comprehensive as Eccutek. I know for sure it does many in the list, but not sure about all.
Currently..
1. Adjust open loop Fuel tables No.
2. Adjust timing tables? No.
3. Adjust tip-in enrichment? No.
4. Adjust global injector scaling? No.
5. Adjust injector dead time? No.
6. Adjust BCS duty cycles (to change boost levels)? No.
7. Adjust idle rpm? No.
8. Adjust rev limit? No.
9. Adjust launch limit?No.
10. Log knock? YES
11. Clear DTC's? YES
12. Export logged parameters to excel or external format? YES, excel.
13. Log my Wb02 through the AP as well? I don't think they released support yet
14. Surf the web kiddingNo.
However, like Razorlab said, the "No's" should be enabled once the new Racer Tuner is released.. (minus #14)
10. Log knock? YES
johnnnyjeans
Cobb AccessPORT
Jun 4, 2012 09:30 AM
pltek
Mar 17, 2009 07:33 AM
