Resetting ECU= Lost Tune?
Old Apr 17, 2009 | 04:38 PM
Poondoggs's Avatar
So one of my intercooler pipes blew off and I had to reset the ECU after I fix the issue. I disconnected the positive terminal in the engine bay. I had a custom tune, and now I notice that I have lost top end power, I feel I have "lost" my tune, it feels stock. Does disconnecting power make you lose your tune?
Old Apr 17, 2009 | 05:20 PM
Mr. Evo IX's Avatar
No it doesnt, maybe you still have a boost leak remaining.
Old Apr 19, 2009 | 03:13 AM
EndlessRed's Avatar
lol your ic pipe blew off? i have a hard time imagining that, as i would think a ic pipe that blew off while driving would mean "omfg FAIL"
Old Apr 19, 2009 | 03:25 AM
storm_trooper's Avatar
actually no your wrong you fail.... to much boost = your IC pipes blowing off..... very common with higher boost... btw OP im not sure if resetting your ECU makes your tune go away. contact your tuner to find out... good luck, oh and make sure you tighten down your IC pipes. has happened to me before.
Old Apr 19, 2009 | 01:35 PM
EndlessRed's Avatar
how am i "wrong" and "fail" when i can't imagine something? are you retarded? learn to strap down your damn pipe.
Old Apr 19, 2009 | 01:40 PM
SilverShadow03's Avatar
^ storm_trooper OBVIOUSLY interprets everyone's comments way too literally.
To OP, no, resetting your ECU (disconnecting batter) does not remove your tune. If you reflash your ecu (by the dealer, as an example), then yes, you would have lost it.
Old Apr 19, 2009 | 02:23 PM
WarmAndSCSI's Avatar
Just shut up. You're the retarded one. There's nothing wrong or "fail" about somebody's IC pipe blowing off. Don't sit here and insult somebody who is just asking for help.
To the OP, invest in some t-bolt clamps or constant-tension worm clamps.
Also, your tune is still there. It's probably all in your head or you have another boost leak. You'd definitely be able to tell on the boost leak because your spool would be taking a huge hit.
Old Apr 19, 2009 | 02:48 PM
EndlessRed's Avatar
oh great another guy who takes it all too seriously. i was referring to storm_trooper's post by the way, but whatever. i'm not gonna waste more time arguing something pointless. good day
Old Apr 19, 2009 | 03:10 PM
Your original post. Completely and utterly condescending and uncalled for. Didn't even help the OP. This isn't an off-topic style forum. This is a technical forum. People are SUPPOSED to be serious here because this is where people ask for legitimate advice.
I'll let the mods deal with you... I've already given my input and advice to the OP of this thread and I'm done.
Old Apr 19, 2009 | 09:07 PM
Thank you. that was my point. why comment if your not gonna help.
and how can you take endgamexiii's any other way then what he said? Like I said, you could tighten it down to what you seem to be enough, but if you crank your boost, its quite easy to blow off your IC pipe(s)...... like WarmAndSCSI mentioned, invest in some tbolt clamps.
/thread
Old Apr 20, 2009 | 10:57 AM
MOB EVO X's Avatar
So if I got a reflash from the dealer and I disconnected my battery means I lost the reflash?????
Old Apr 20, 2009 | 11:13 AM
JoeyM3's Avatar
no, you only lose a flash when a new map is flashed to the ecu. just think of it like a computer hd, do you lose everything when you turn off the computer?
Old Apr 20, 2009 | 11:17 AM
MOB EVO X's Avatar
I don't quite get that lol. Can you explain more. I'm having a retarded moment lol
Old Apr 20, 2009 | 12:04 PM
the_window's Avatar
You lose your OLD flash only when you flash a NEW map to the ecu.
Old Apr 20, 2009 | 12:06 PM
MOB EVO X's Avatar
Lol duh!!! sorry about that lol I can't believe I didn't get that.
