1000 cc Injectors
Old Apr 21, 2009 | 04:51 PM
Hiboost's Avatar
Question 1000 cc Injectors
I'm getting a GT3076R turbo soon and wanted to line up a solid set of injectors for the car. I know that 800 cc injectors would probably be enough to keep the duty cycles below 90% but I would rather buy them once and not have to worry about them again. I want to stick with direct fitment, high impedance injectors.
So far I've only seen these available so far:
Injector Dynamics 1000 cc ~$460
http://www.t1raceparts.com/Injector_...d1000-evox.htm
I know the Deatschwerks 800 cc injectors can be had for about $400, does anyone know the eta for their 1000 cc injectors to start shipping?
Old Apr 21, 2009 | 05:38 PM
GST Motorsports's Avatar
The Bosch 1000cc injectors are shipping.
They seem to work great so far.
We tuned a Evo 10 on E85 with the Bosch 1000cc injectors and they worked great.
Old Apr 21, 2009 | 06:25 PM
Evo a Mula's Avatar
thanks gst deff going to look into that
Old Apr 21, 2009 | 09:10 PM
HB Speed's Avatar
I have Deatschwerks 1000's that i am beta testing plug n play no adapter harness needed
coming soon to a Dyno near you!
Old Apr 22, 2009 | 04:55 AM
Mojito's Avatar
I'm also thinking of getting a bigger turbo. Is it necessary to also upgrade the fuel rail when swapping injectors? Also, what kind of drivability issues can I expect when I go to bigger injectors?
Old Apr 22, 2009 | 05:15 AM
burnings's Avatar
Upgrading of injectors is only used to supplement additional boost / power needed. I believe in using what you need because there is no point in tuning the injectors for 40% duty cycle while stock can be used at 90%.
There should be no drivability issues if properly tuned and dialed in.
Old Apr 22, 2009 | 05:40 AM
Mojito's Avatar
I agree with the get-what-you-need concept, that's why I'm going to upgrade to 800 cc injectors. But the question remains: do I need to upgrade the fuel rail?
Old Apr 22, 2009 | 08:31 AM
Hiboost's Avatar
note: pictures shows plug and play adaptor which is on hold for the moment, not included
Looks like the above linked Injector Dynamics 1000 cc injectors are lower price now, $425, but don't include the plug and play adapters. I'm assuming that some splicing would be straight forward but not sure. Anyone have experience with them?
I have Deatschwerks 1000's that i am beta testing plug n play no adapter harness needed. coming soon to a Dyno near you!
Any idea of ETA on these? If I don't want to get this all installed before my next DE at Watkins Glen I can wait til early June before deciding.
Any updated info would be appreciated!
Old Apr 25, 2009 | 05:53 AM
Guru's Avatar
Those are actually Yaw Power. You can find them for about $350 ish a set elsewhere with the plug and play connectors. Deautschwerks is a good month or maybe two months away.
Old Apr 25, 2009 | 10:38 PM
mrfred's Avatar
Old Apr 26, 2009 | 07:04 AM
Guru's Avatar
Originally Posted by mrfred
Injector Dynamics injectors are not Yaw Power.
http://www.injectordynamics.com/garbage.html
HMm Yaw Power also machines the hats for the injectors, they also use the adaptor connector and they also have a high impedence 1000cc injector. They Don't make it, just resell it but in the end the injectors itself is the same. I would wait for the Deautschwerks
Old Apr 26, 2009 | 08:54 AM
mrfred's Avatar
They look similar, the Yaw Power stuff is not the same.
Old Apr 26, 2009 | 04:26 PM
burnings's Avatar
I would suggest upgrade fuel pump and fuel rail but dun hop on to the injectors yet.
Old Apr 28, 2009 | 06:26 AM
Tony1's Avatar
Paul Yaw, from Yawpower, is also Injector Dynamics. ID is the new line of fuel injectors done by Yawpower.
You won't find them for $350 though.
Old Apr 29, 2009 | 09:14 AM
Tractionlimit's Avatar
To run E85 on an upgraded turbo, 1200s would be best. Unfortunately, that isn't an option yet. I have 800s now for Red/93oct and am waiting for AMS to get their set of the Deatschwerks 1000s to switch to E85. I think the 1000s will be maxed out with E85, but we'll see. AMS said it'll be a month, so I'd give it at least two for us regular guys.
