Car acting weird when exhaust got installed
Old May 12, 2009 | 05:09 PM
amrock88's Avatar
Ok so im running a Cobb Stage 2 map 93 octane with the SF intake option. I got the SF intake installed and a full turbo back...i had the downpipe and testpipe innstalled before i put the cat back on and when i did it seems like the car is hesitating and jumping rpm's real quick when i punch it. For example if im in 3rd gear at 2000rpms and kinda give it gas it will jump to 3200 then drop to like 2800 then pull hard, but it seems like its running a little off even with the tune on it....it does this in every gear, if i ease into the gas then it will pull smoothly. its a buschur quiet catback, im just wondering if any body has this hesitation problem too but it could be turbo lag.....
Old May 13, 2009 | 05:21 PM
amrock88's Avatar
uhhh...lol....nvm burnt clutch...just ordered stage 3 clutchmasters and flywheel.....thats why it wasnt pulling hard...it was just burning clutch bad instead..
Old May 13, 2009 | 05:30 PM
JoeyM3's Avatar
yup classic burnt clutch symdrome. how many miles do you have on the clutch?
Old May 13, 2009 | 09:47 PM
EVOX56's Avatar
glad you found out the problem. Good luck with the clutch replacement/install.
Old May 13, 2009 | 10:26 PM
flyguycfi's Avatar
Yea how many miles?
Launch much or no?
Old May 13, 2009 | 10:51 PM
flyguycfi's Avatar
Oh I'm totally going Exedy twin when mine goes out.
That and the AMS clamp thing they just came out with for $50.
Old May 14, 2009 | 06:40 AM
amrock88's Avatar
well i just rolled over to 16000 and i went with the clutchmasters cause of their reputation...excedy still has a good clutch system though....and i also ordered the AMS clamp lol .....btw the stealership was charging me $1700 for just labor on it...i found a shop that said they would do it for $800...and i only launched it 1 time at like 4000 miles....its weird cause when i put the cat back on then the next day it went out...
Old May 14, 2009 | 09:43 AM
alex3dworld's Avatar
did you reset the learning proccess with your AP2?
do it. if no matter what you changes in your maps and still is doing the same = clutch burn
Old May 14, 2009 | 08:21 PM
amrock88's Avatar
how would i do this???
biqsosa
14
May 9, 2016 08:12 PM
hooliganSKATE
Jul 16, 2015 06:21 AM
GetterDragun
Feb 22, 2011 08:24 PM
MitsuJDM
18
Sep 8, 2009 05:19 PM
Mojito
14
Sep 4, 2009 04:03 AM
