Knock when slipping clutch from a stop? Up to 6 knock sum at 1200 rpm's
Old Jul 16, 2009 | 03:43 PM
LaXGSR's Avatar
Anyone else log knock when driving gently from a stop? I sometimes can get as much as 8 knock sum between 1000-2000 rpm's at around 60-80 load. This is while driving normally (not hard launches or acceleration by any means), and it persists even after done slipping the clutch. It will sometimes record knock up to 2500 rpm's during light, normal driving. Typically the knock sums will be around 3-5, but I have seen as high as 8.
Is this real knock? Should I try to tune it out? The stock timing map looks a little funny around 60-80 load between 1000 to 2000 rpm's. I tried lowering timing in this area by 1 degree and smoothing it out, but it didn't seem to help. Anyone else log this problem during normal driving?
Old Jul 17, 2009 | 01:41 AM
Bob_tm's Avatar
Yes, I have up to 10-15 knocks. Afr was too hight. Go to closed loop and more, more fuel! With lover AFR it's much better, but sometimes still knocking a little. Lower AFR at low RPM will help with spool too!
Old Jul 17, 2009 | 07:38 AM
LaXGSR's Avatar
Hmm so you're saying I need more fuel? I thought I can't adjust closed loop - won't the ECU automatically target 14.7? Without a narrowband simulator, how can I affect how much fuel during closed loop? Thanks!
Old Jul 17, 2009 | 10:08 AM
Bob_tm's Avatar
Oh, sorry. Open loop of course. Put less load for low rpm in "Open Loop Load High Octane" tables and tune afr for new cells.
Old Jul 18, 2009 | 06:07 AM
LaXGSR's Avatar
Hmm is your car stock? Mine is, and I wonder why it would knock at such low rpm's stock in closed loop - shouldn't the ECU be able to handle this? I'm a little wary of forcing it into open loop and tuning the AFR at such low load for daily driving (around 60-70 load between 1000-2000 rpm's).
Old Jul 18, 2009 | 12:38 PM
Bob_tm's Avatar
turboback and ecu tune
Old Jul 18, 2009 | 05:56 PM
EvoX777's Avatar
What are you guys logging with.
Old Jul 18, 2009 | 06:39 PM
Excalibur's Avatar
I wonder if this isn't phantom knocking.
Old Jul 21, 2009 | 07:46 AM
LaXGSR's Avatar
Logging with evoscan using mode23, and I also do wonder if it's real knock...
Ray521
Sep 10, 2015 11:10 AM
jcsbanks
Sep 19, 2009 01:34 PM
evascst
Nov 21, 2008 02:28 PM
NIevo
Oct 12, 2006 09:30 PM
ant_turbo
Sep 25, 2006 03:08 PM
