ECUFlash idle tables with A/C on
Old Sep 4, 2009 | 03:55 PM
Kracka's Avatar
I've been having a bit of a problem getting my car to idle well with my cams, but only when the A/C is on. With the A/C off I've gotten my idle tuned perfectly. It almost seems like I'm missing a table that could greatly help me out. Does the Evo IX 88590015 ECU have a "Desired ISCV intial step position with AC on-Drive" table? I have one for AC off-Neutral, AC off-Drive, and AC on-Neutral. My car sometimes idles low with the A/C on and when coming to a stop the RPM's dip and engine sometimes stalls.
Old Sep 4, 2009 | 03:57 PM
Raceghost's Avatar
What rom are you using?
...oops missed it in the post. I am not familiar, sorry I could not help. Bump for you.
Old Sep 4, 2009 | 04:25 PM
fryedchikin's Avatar
You might find what you are looking for in these threads.
https://www.evolutionm.net/forums/ec...t-working.html
https://www.evolutionm.net/forums/ec...sassembly.html
Old Sep 5, 2009 | 06:38 AM
Kracka's Avatar
Originally Posted by fryedchikin
Thanks, I'll check those out!
Old Sep 5, 2009 | 05:29 PM
biggie5252's Avatar
What version of ecuflash? I have a desired ISCV initial position ac on table. I bumped up the bottom two cells up about 12 points to cure the rpm dip when you let off the throttle.
I also have another table that's labeled target idle ac on or something like that. Sorry my laptops not with me.
Old Sep 7, 2009 | 07:07 AM
Kracka's Avatar
I have ECUFlash v1.42. What are you using?
Old Sep 7, 2009 | 07:54 AM
biggie5252's Avatar
The newest one. IIRC the tables have only been in the last couple versions.
Old Oct 3, 2009 | 09:29 AM
cij911's Avatar
I too would love to increase my idle RPM when the AC is on, how are people doing this ? (I am on stock cams, yet the car feels like it is ready to stall while at idle and AC on full...)
Old Oct 3, 2009 | 04:13 PM
biggie5252's Avatar
Desired ISCV intial step position with AC on-Neutral is a good place to start. Bump up the bottom two cells by 10-15. That will help the rpm drop when you first let off the throttle.
Then there's Target Idle RPM with AC on #1 and 2. You can try raising those tables a little bit. I'm not sure what the difference between the two is.
TouringBubble
Oct 10, 2025 11:11 AM
rich3389
Sep 8, 2024 07:27 AM
simple_lancer
Oct 14, 2020 02:18 AM
PPM
Apr 2, 2015 09:35 AM
TouringBubble
Aug 1, 2008 07:33 AM
