how to make knock sensor less sensitive?
Old Jan 21, 2010 | 03:23 AM
YaroRS's Avatar
Guys, I got evo 10 with forged JE pistons and Manley rods. After fitting those pistons the engine started knocking (knock sum 1-4) ocasionaly without any pattern. So i suppose this happens because of new pistons. Can someone advise me how to get rid of those knocks ?
Old Jan 21, 2010 | 03:43 AM
BigT's Avatar
What is your piston to well clearance set to?
Does it happen at any boost/timing/mivec settings?
Old Jan 21, 2010 | 04:40 AM
tephra's Avatar
The knock setup on CZ4A is 95% the same as CT9A
I can give you the knock maps (gains/adders/multipliers), however you/your tuner REALLY need to be sure it's not real knock...
Old Jan 21, 2010 | 04:51 AM
cfdfireman1's Avatar
What will "(knock sum 1-4) ocasionaly without any pattern" affect anyway?
Old Jan 21, 2010 | 07:43 AM
YaroRS's Avatar
Yes please, any chance you could e-mail it to me to yossipov@mail.ru
YaroRS's Avatar
well, as I understand it pulls timing.
Old Jan 21, 2010 | 09:54 AM
E6-X's Avatar
knock sum of 3 & above goes to low octane timing map
Old Jan 21, 2010 | 10:32 AM
UT_EvoX's Avatar
Not exactly...
Any knock count causes interpolation between the High and Low Octane Timing & Fuel maps. The higher the count, the more it leans toward the Low maps.
Old Jan 21, 2010 | 11:08 AM
goofygrin's Avatar
Yup, I saw 1 count and it pulled a * of timing this morning.
ETA: I think the title should be "sensitive" not "sensible" lol.
Old Jan 21, 2010 | 11:14 AM
xRoguex's Avatar
Just like it should be FYI? Not estimated time of arrival?
Old Jan 21, 2010 | 11:35 AM
goofygrin's Avatar
ETA = Edited to Add (I edited the post to add that info).
Old Jan 21, 2010 | 12:39 PM
AIK's Avatar
AIK
You could not lift compression ratio casually?
Old Jan 21, 2010 | 02:44 PM
tephra's Avatar
actually only a repeated and sustained KnockSum of 6 or more will cause the ECU to start interpolating to the low oct maps...
The affect is additive, so if you get a BUNCH of 6+'s then the ECU will move more and more towards the low oct maps..
Yaro - I agree with the others, 1-4 is nothing to be worried about, if you were consistantly getting 10+during a pull and you know it was false then we can fiddle with the maps...
Old Jan 21, 2010 | 03:05 PM
UT_EvoX's Avatar
That's how the "octane %" and cruise/light accel are affected, yes. But I've ALWAYS seen the Evo X dynamically pull approx timing 1 degree per 1 count of knock during any given pull. I try to aim for 0 knock just so my timing curve stays smooth.
Old Jan 21, 2010 | 03:42 PM
tephra's Avatar
Yes, ontop of the octane treatment you have regular timing pulled.
Normally it's 1* per 3KS...
