tune a must before turbo back 2011?
Old Jun 6, 2011 | 07:28 AM
Carnifex's Avatar
Just entered the Evo world about a month ago and with the 2011 being a bit different ECU wise ( not sure how ) is it safe to have a turbo-back exhaust before a tune??
thanks,
Old Jun 6, 2011 | 07:35 AM
ProjectGSX's Avatar
Im certainly not the expert here, but I would be really surprised if a tune was required. You arent affecting air flow to the engine like if you added an intake or a boost controller.
That being said, I keep hearing there is some HP to be gained with a tune on an 11, even though its not as much as the previous years.
Old Jun 6, 2011 | 08:36 AM
derekste's Avatar
yep, plenty safe.
Old Jun 6, 2011 | 09:26 AM
Kracka's Avatar
Short-downpipe I would say no, not required, but obviously a good thing to do. With a full o2 elim dp I would say yes, tune required since mine threw my AFR's off by quite a bit (just my personal experience, results will vary).
Remember though, ALWAYS log your car after making changes to your setup. Sometimes certain parts can have random side-effects you weren't expecting and it's better to have the surprise on a laptop/AP screen rather than in a puddle on the side of the road.
Old Jun 6, 2011 | 05:12 PM
guswaym's Avatar
unless you have a high flow cat youll want it or youll have cel on all the time
Old Jun 6, 2011 | 05:30 PM
OZ_2435's Avatar
Mine seems to run fine without a tune. TBE with test pipe. Ran an O2 spacer for the cel. Car runs rich ofcourse, but that is the way they come. Tune is coming in the near future, from the good folks at CBRD.
Old Jun 6, 2011 | 05:35 PM
NewEvolutionIX's Avatar
Just buy spark plug spacers and cel problem solved! Thats what I did, No cat on my car
Old Jun 6, 2011 | 07:04 PM
guswaym's Avatar
i believe you are reffering to spark plug defoulers and yes those do work but i mean your not going to be able to get the full power outta your exhaust without a tune anyways i have full turbo back invidia im waiting to install untell the cobb comes out
Old Jun 6, 2011 | 07:12 PM
Boostfiend's Avatar
The best idea would be to save up and do everything all at once; intake, exhaust, tune.
Old Jun 7, 2011 | 04:11 AM
Carnifex's Avatar
Old Jun 7, 2011 | 06:28 AM
tephra's Avatar
the 2011 exhaust flows better than the 2008/2010
I would be tempted to just go the tune
Old Jun 7, 2011 | 07:10 AM
Carnifex's Avatar
What is the difference? Bigger pipes or better bends? TIA
Old Jun 7, 2011 | 07:13 AM
tephra's Avatar
better muffler internals
you will still make more power with a 3" TBE, but it wont be as much as before..
Old Jun 7, 2011 | 07:38 AM
4wdrifter's Avatar
just something to think about, your exhaust will flow a lot better with a turbo back. you might see a little higher boost numbers due to not having a cat. this is much more pronounced on other cars like the 3rd gen rx7. you will more than likely be fine but i would get a tune asap
Old Jun 7, 2011 | 10:26 AM
tonyboy's Avatar
like what they said, you'll be fine. results may vary like what kracka said, so better log just to make sure. it is recommended and ideal to have a tune.
and btw, make sure you align those gaskets for the o2 and dp, before the o2 sensors. having exhaust leaks will make you leaner depending on the size of the exhaust leak.
AFI Turbo
AFI Turbo – Phoenix, AZ
13
Nov 12, 2012 03:54 PM
KevinD
North Texas Evo Club (NTEC)
26
Jan 10, 2012 06:25 PM
boomn29
Automotosports - Illinois
Oct 30, 2011 05:48 PM
SLO-EVO
West Region
110
Oct 26, 2011 10:24 AM
Bear.914
Apr 20, 2011 08:48 PM
