Crappy idle followed by stalling out
Old Jul 29, 2011 | 09:51 PM
tico915007's Avatar
Car will not idle for the life of it and within a minute of trying to idle it will turn off and cant get it rolling either.
could it be a vacume leak?
Old Jul 29, 2011 | 10:40 PM
goldenEvo's Avatar
double check for vacuum leaks, like the vacuum hose to your fuel regulator, the seals around the injectors. you may try another mass air flow sensor. gl
Old Jul 30, 2011 | 10:51 AM
rrkpitt15's Avatar
check the crank case vent that leads from the valve cover to the intake mani
Old Jul 30, 2011 | 12:48 PM
tico915007's Avatar
I checked my hose from valve cover to intake mani it's on good but with the clamps on I can still pull it off with my hand is that normal
Old Jul 30, 2011 | 03:13 PM
spooln3's Avatar
I only had half of this issue, with the crappy idle, but was intermittent. Hope the MAS fixes this for you. Good luck.
Old Jul 30, 2011 | 04:38 PM
tico915007's Avatar
delete
Old Aug 1, 2011 | 07:23 AM
WhiteCtEvo's Avatar
Keep us posted, my car once in a while idles really low but does not shut off. Im curious what the dealer will say. Good luck!
Old Aug 29, 2011 | 12:35 PM
walukab14's Avatar
bro i got 08 gsr about 26k miles i've having problem long time ago bout rough idle and hard starting,recently may car is acting up again i decided to clean the throttle with rug performed idle relearn it did help alot that i must say acceleration response way much better than before,until the next day it idle so bad that it starting to stall on me,try to restart it the car it did start and stall try to give it gas its choking so i put it 1st step on it,the car is bucking like crazy until it catches and move i didn't till i got to work from that point i knew its throttle body thank god my buddy from nextdoor mitsu shop hook me up and put new throtle on my car,since then i never have any idling issue or stalling,this problem is like the one on nissan car
Old Sep 4, 2011 | 03:14 PM
Dynotech Tuning's Avatar
Worst Grammatical post ever
This needed to be said. That is all.
Old Sep 5, 2011 | 09:16 AM
Supraboy1's Avatar
Now its clear.... why America is ranked lowest in the world for "readin, ritin, and rithmatic."
Old Sep 7, 2011 | 01:42 PM
tico915007's Avatar
LMAO at the unreadable post.
Ended up getting the problem fixed was a lose vacume line back towards the intake
Old Sep 10, 2011 | 03:02 PM
Boosted Tuning's Avatar
Originally Posted by dynotech tuning
worst grammatical post ever
Originally Posted by supraboy1
now its clear.... Why america is ranked lowest in the world for "readin, ritin, and rithmatic."
+1
bluebyyouEvo03
Oct 26, 2008 06:36 AM
Oracle1
Apr 6, 2008 08:39 PM
bigric09
Jun 6, 2007 09:07 PM
Mad_SB
Jul 14, 2006 04:15 PM
TEJ
Lancer Troubleshooting
Feb 9, 2006 09:30 AM
