Random Misfire
Old Sep 9, 2011 | 09:43 PM
MIVEC 4G63's Avatar
Random Misfire
Hey guys, I wanted to know why this code came up before. I have a stock ecu and 1000ccs, I know that alone sounds like a good enough reason for the CEL but could a little more fine tuning eliminate this stupid CEL? I use the most awesome tuner on the planet but could he have missed something? I also had an o2 one come up and I know he got rid of that even being possible so why did it come up that one time?
Old Sep 16, 2011 | 08:00 PM
MIVEC 4G63's Avatar
Really no one had this problem or knows anything about it?
Old Sep 19, 2011 | 06:31 PM
iowa_guy's Avatar
Originally Posted by MIVEC 4G63
Hey guys, I wanted to know why here and there this code pops up. I have a stock ecu and 1000ccs, I know that alone sounds like a good enough reason for the CEL but could a little more fine tuning eliminate this stupid CEL? I use the most awesome tuner on the planet but could he have missed something? I also had an o2 one come up and I know he got rid of that even being possible so why did it come up that one time?
What do you mean o2 one? pre or post cat? he probably got rid of the post cat code?
Is there a way for you to get the freeze frame data from this trouble code? it should go along way as to finding what the computer is seeing that sets a missfire
Im new to the actual tuning side, but have several years of experience on the repair side.
Old Sep 21, 2011 | 07:08 PM
MIVEC 4G63's Avatar
no the o2 code came up once but the random misfire comes every so often, we went aggressive on the timing but not bad at all, absolutely no knock count. why do i get random misfire? weird...
Old Sep 22, 2011 | 04:05 AM
iowa_guy's Avatar
Thanks to OBD2 whenever an emissions related trouble code is set...there is also a snapshot taken of the datastream at the time. If you have, or can find someone who has access to the right scan tool, you can pull up this information and share it with us on here or with your tuner. Its referred to as "freeze frame" data, and should give you some insight as to what was going on when the random misfire or o2 code was set.
Not all scan tools have the capability, and most cheap "code readers" do not.
EvoNvee
Nov 29, 2010 09:29 AM
commandwolf
Lancer Tranny/Drivetrain Tech
18
Dec 2, 2009 03:38 PM
Ozdriver
Lancer Troubleshooting
Oct 18, 2009 03:56 PM
Blue Evo 8
Jan 9, 2006 12:09 AM
Trustz
Jul 9, 2003 05:06 PM
