rear 02 CEL fix
Old Oct 17, 2010 | 02:04 AM
EvoNvee's Avatar
rear 02 CEL fix
I read through darkmitsu's write-up on how to wire up the AEM UEGO for datalogging with Evoscan w/o the serial cable. At the end, he shows how to get rid of the CEL that is tripping now. The problem is is i don't see those tables in ECUflash. I have searched and searched, but I found nothing helpful.
Anybody know what to do or where to go?
Thanks
Old Oct 17, 2010 | 08:50 AM
raasfaas's Avatar
If you're running any of Tephra's roms there is an option to disable to rear O2
https://www.evolutionm.net/forums/ec...hramod-v7.html
You can also do it through the periphery bits...what version of ecuflash are you running?
Old Oct 17, 2010 | 09:39 AM
EvoNvee's Avatar
I'm running v2.7. That link you posted up kinda confused me. I apologize for the ignorance since I'm still getting familiar with all of this, but I'm not too sure what a Tephra rom is exactly. And also, I'm pretty sure that i have the latest version of ECUflash(v1.42), but the pic of the ECUflash tables towards the bottom of the thread has more tables than I do.
Old Nov 11, 2010 | 11:22 AM
EvoNvee's Avatar
Is there any way I can Fix the CEL without resorting to a Tephra rom? I have been running the spacers in the 02 sensor bung (I believe it's referred to as the "mechanical fix") for a while with no CEL, but as soon as installed my AEM UEGO and hooked up Evoscan and ECUflash, it came back on. Thanks guys.
Old Nov 12, 2010 | 02:17 PM
raasfaas's Avatar
Someone correct me if I'm wrong, but I believe disabling ecu periphery4 (FEA) bit15 addresses that. (Change the value from 1 to 0)
Old Nov 13, 2010 | 12:20 AM
EvoNvee's Avatar
thanks. someone else please chime in if you know, but for now i'm going to disconnect my battery to reset everything and change that periphery you mentioned. i'll keep you updated.
Old Nov 13, 2010 | 09:35 PM
Hi Im Vinh's Avatar
bump would like to know the answer as well , I searched around and found this here https://www.evolutionm.net/forums/5353216-post148.html
Haven't tried it yet, maybe 2mrw I will
Old Nov 18, 2010 | 06:06 AM
EvoNvee's Avatar
I tried this the other day with no success. Anyone else have any ideas?
Old Nov 18, 2010 | 06:24 AM
sk8terdude929's Avatar
I used a resistor like in the first link, got a pack of them from radio shack for 1.99$ i think. there cheap either way.
https://www.evolutionm.net/forums/ec...heres-how.html
https://www.evolutionm.net/forums/ec...sim-patch.html
https://www.evolutionm.net/forums/ec...es-how-10.html
Old Nov 29, 2010 | 09:29 AM
EvoNvee's Avatar
This looks like an option for someone that wants to remove their rear 02 sensor completely. I don't have a reason to remove it, so i was planning on keeping it in there. Also, the above post includes links that suggest options involving alterations to your XML file. I'm having problems editing my XML. It keeps denying my access. This is the same reason i haven't been able to properly complete the install of the Tephra rom. I have been trying to find a way to do it, but I'm having difficulties. HELP!
Jakeg97
133
Jul 30, 2021 08:19 AM
SPOOLIGAN
Sep 8, 2016 12:07 PM
Raikiri
Dec 21, 2009 10:41 PM
Blue Evo 8
Jan 9, 2006 12:09 AM
Trustz
Jul 9, 2003 05:06 PM
