Sponsored by:
Sponsored by: CARiD
clutch pedal hit the floor this morning...
Old Nov 19, 2012 | 01:08 PM
evotap's Avatar
CMC let go. stock clutch , 31k . AMS cmc ordered . i wasnt expecting to upgrade until my clutch was shot. oh well, happy monday.
Old Nov 19, 2012 | 01:13 PM
Kracka's Avatar
Pretty rare to see a 2010 failure, especially on the stock clutch. Are you sure that's your problem?
Old Nov 19, 2012 | 01:28 PM
evotap's Avatar
Yes sir
Old Nov 19, 2012 | 01:42 PM
BBQman's Avatar
I think some early 2010 EVOs may be affected. I bought my 2010 in November 2009, and in June 2010 with little mileage and stock everything, the master died without warning- 1 corner from my home, that made it OK.
It happens.
Old Nov 19, 2012 | 02:25 PM
evotap's Avatar
my evo was built in june of 2010. mc let go about 3 miles from home. could have been worse for sure.
Old Nov 19, 2012 | 02:51 PM
RAI's Avatar
RAI
Why are the 2010's so special? I thought Mitsu never changed them?
Old Nov 19, 2012 | 05:44 PM
Magik's Avatar
Is this a frequent issue?
Old Nov 19, 2012 | 05:50 PM
evotap's Avatar
apparently. the oem clutch master cylinder is made of plastic. the kit i bought is basically an adapter to use the evo 9 aluminum cmc.
Old Nov 19, 2012 | 06:41 PM
EVOEvolved's Avatar
That is better, why would Mitsubishi be so cheap? Well their metal sucks we all know that! I would imagine the plastic used may swell letting the rubber cups inside push fluid around the bore? Who knows the real issue Ia m just trying to make sense of it.
Good job ordering a better one. Honestly when you get your old one off you should take it apart with pictures and measure a few things?
Good luck man!
Old Nov 19, 2012 | 07:03 PM
evotap's Avatar
i may, but i'll probably just slam it in the garbage
Old Nov 19, 2012 | 07:09 PM
EVOEvolved's Avatar
Hah! You really should look into it and do a write up (: or send it to me and I would!
I love knowing why things do, and do not work
Old Nov 20, 2012 | 07:40 AM
RAI's Avatar
RAI
More or less frequent, especially on cars with upgraded clutches.
I can't help but ask again--why are the 2010's so special? I thought Mitsu never changed their CMC designs?
Old Nov 20, 2012 | 08:07 AM
Get Rad's Avatar
72K on stock 2010 clutch and still running strong.
Old Nov 20, 2012 | 11:04 AM
Kracka's Avatar
Each year they have become more reinforced. They're still made of plastic, but it's only the 2008's with somewhat high failure rates.
Old Nov 20, 2012 | 12:58 PM
RAI's Avatar
RAI
Interesting. Has anyone been able to do side-by-side's?
