Another SST Thread...
Old Jan 23, 2009 | 11:36 PM
gunzo's Avatar
Originally Posted by MR-X1212
yea, i know, i'm a hot head. just frustrated. kinda took it out on him. It is quite easy to duplicate in normal auto mode, or manually shifting in normal at wot, it will "slip" through 3rd. i have honestly not tried it in sport because if it did it in s-sport i was confident that is would duplicate as well.
Dude .. I'm not telling you what any tom, dick or harry knows .. I'm telling you HOW THE ECU works in conjunction with SST ..
The perceived SLIPPAGE is just plain SST not engaging because of an ECU mismatch with the SST .. and YES it really feels like slipping clutch BUT IT IS NOT !
The safety protocols will cut in when that happens and you'll get a CEL ..
Old Jan 24, 2009 | 05:11 AM
MR-X1212's Avatar
alright man, appologies, So then I should I expect to see this problem again after I re-map with ECUtek?
Have you changed your shift points? If so how high and how did it react?
Old Jan 24, 2009 | 03:59 PM
smgevo's Avatar
when you retune, set the tq max lower to 300-320. You'll make less power, but not get the ECU "slip".
Old Jan 25, 2009 | 07:11 AM
MR-X1212's Avatar
Thanks for the tip.
chris the man
Mitsubishi TC-SST Discussion
Jun 5, 2013 09:21 PM
Evolution>Sti
May 10, 2013 08:22 PM
CU125
Apr 30, 2013 10:57 PM
Jasoob
May 8, 2012 05:28 AM
617G
Apr 7, 2009 06:07 AM
