Launch Control???
Old Jun 18, 2009 | 09:32 PM
Brady 154's Avatar
That happened to me the first time I tried it also. I'd say to make sure you have the brake pressed pretty hard and then floor the throttle (don't be timid on the throttle).
Old Jun 19, 2009 | 03:44 PM
SUPRAEATER's Avatar
I think it was the brake not being pressed hard enough, works now. Bit of a let down. I thought it would have been more violent.
Old Jun 19, 2009 | 04:02 PM
LVSBB6's Avatar
how much quicker is 0-60 by using launch control?
Old Jun 22, 2009 | 10:04 AM
kozmic27's Avatar
I did some experimenting with mine, whithout actually launching it. I believe it is the tps position that determines whether you are in launch mode or not (assuming you are in s-sport with asc off).
With the throttle in the first 50% of travel or so it seems that the transmission wants to go, so it drags down the engine. I also noticed that when pushing the throttle to 50%, that once the trans started loading the engine, it would not allow me to launch, even if I mashed the gas down all the way.
However, if you push the throttle to full 100% right away with the brake pedal held, it seems to get the message you want to launch, and does not engage the clutch unatil you relase the brake.
Also when I would go to 100% throttle right away, it would let me back off the throttle to attempt to control the rpm. It does however seem kind of touchy, and will take some practice to get the technique down. Fortunately, it will let me practice without actually launching the car, so the trans might actually survive my learning process.
Old Jun 22, 2009 | 05:24 PM
lousEVOxmr's Avatar
ive launched it on my first try .... and fast very very good .... o-60 feet was under 1.85 sec :P
Old Jun 22, 2009 | 05:30 PM
5harkology's Avatar
That's very good news and a great 60ft time for a automated manual. How did you record this time, were you at the track?
Old Jun 26, 2009 | 10:26 PM
boostsaves's Avatar
When you launch at the track try snow mode. I have gotten my best times and 60ft in that mode. 12.6 at 108 1.760 ft
Old Jun 27, 2009 | 11:10 PM
SUPRAEATER's Avatar
was just at the track lastnight, 60ft was 2.09. 13.98@100mph, all stock
Old Jul 27, 2009 | 11:20 AM
LVSBB6's Avatar
Tried it yesterday on Tarmac mode 60ft was 1.77 and 0-60 4.22s.
Old Jul 27, 2009 | 11:36 AM
lousEVOxmr's Avatar
i went in napierville on highway 15
i did 1.8 last week for o 06 and i did 13.08 !!!!!!!!!!!!
Old Jul 27, 2009 | 11:40 AM
lousEVOxmr's Avatar
i did 106 mph by the way !
Old Aug 13, 2009 | 06:21 PM
Rcizzle's Avatar
Originally Posted by 08 Evo X MR
dont launch alot in your mr, you will mess it up for good.
how many times can you launch it before it's "done" or before it starts to go.
Old Aug 14, 2009 | 07:56 PM
lousEVOxmr's Avatar
its like how many time do you slip your clutch befor it goes....lol " you never know !! "
aggieEVO
Jun 18, 2015 01:54 PM
Brady Johnson
Sep 17, 2012 10:34 PM
aggieEVO
Jul 6, 2012 06:28 PM
Brady929rr
16
Oct 2, 2009 04:39 PM
