SST FLUID COOLER is out!! with test comparisons!
Subscribe
Aug 22, 2009 | 09:20 AM
Souce: http://www.hks-power.co.jp/products/...uid/index.html
When, SST fluid temperature with such as circuit travelling rises and exceeds constant temperature entering safe mode the fact that it becomes not be able to travel can be evaded. It is the cooling system where travelling in long haul becomes possible by jointly using with the air cooled core of normal. At the Fuji speedway short course it becomes possible to finish to run travelling framework 25 minute. Even with when temperature of the SST fluid rises, the effect of the cooling lap becomes large, re-travelling directly possible.
With normal with travelling of 10 parts with oil sound rise thrust into fail-safe mode. Confronting, 'as for the HKS SST OIL COOLER KIT' equipped car, until it reaches to the same temperature, time by the fact that it removes the insecure element, to be above time, be able to concentrate on driving, it stabilizes and from the fact that you can repeat LAP, it contributes to also time rise.
*Test car is making 360ps, and it takes twice the time for the SST fluid to reach 128 degrees celcius*
The result of the test inside the company HKS, exchange to the bulk core and addition of the fan for cooling not be able to expect the effect, almost it was not different from normal. But, HKS succeeded in reducing the temperature of oil substantially with the individual system. HKS SST OIL COOLER is the necessity in sport travelling by the SST car.
Notes:
There is small processing of the part, but there is no big processing. Genuine fog lamp combined use possible and HKS I/C combined use possible.
Reply 0
Aug 24, 2009 | 03:32 PM
price?
Reply 0
Aug 24, 2009 | 03:38 PM
so if i can understand the horribly translated babelfish output is,
the HKS is a standalone cooler, in which you can be on the track to get repeated lap times, in which the HKS cooler can allow the SST oil to be cooled down at the same cooling RATE if not faster than how the OEM cools down the oil when the car is operated under normal driving conditions. (ie. both cooling rates are the same?)
did i get that right?
Reply 0
Aug 24, 2009 | 03:47 PM
The cooling rate of the HKS SST cooler is double than that of the OEM cooler as stated in the 1st graph. *Test car is making 360ps, and it takes twice the time for the SST fluid to reach 128 degrees celcius*
The 2nd graph is just a demostration of attaching a fan to the OEM cooler vs no fan with OEM cooler. The results is nearly identical.
Reply 0
Aug 24, 2009 | 04:03 PM
126,000 Yen....around 1,100 USD or so
Reply 0
Aug 24, 2009 | 04:37 PM
Thanks
Reply 0
Aug 24, 2009 | 06:19 PM
Quote: The cooling rate of the HKS SST cooler is double than that of the OEM cooler as stated in the 1st graph. *Test car is making 360ps, and it takes twice the time for the SST fluid to reach 128 degrees celcius*
AHh. thanks for the clarification..
twice the time, but does it maintain it, or does that temp still go back up?
Reply 0
Aug 26, 2009 | 04:43 PM
it probably goes up at a very slow process gradually enough time for you not to trigger the warning at the track, definitely the most effective SST cooler option out there and that is proven to work.
Reply 0
Aug 27, 2009 | 03:13 AM
blitz also have a SST Cooler out aswell..
Reply 0
Aug 27, 2009 | 09:23 AM
Quote: it probably goes up at a very slow process gradually enough time for you not to trigger the warning at the track, definitely the most effective SST cooler option out there and that is proven to work.
well... 'most effective' is subjective.. its alsp part marketing...
i'll be making my own cooler once my front bumper arrives from Japan, so then i can accurately plan real estate of where to place this cooler, and an upgraded one for the oil cooler..
Reply 0
Aug 29, 2009 | 12:25 PM
I still find it humorous that my pt cruiser has a bar and plate trans cooler that is front mounted, that is literally 3 times the size of the cooler on my Evo....So when my gf comes home and the pt cruiser is missing its front clip, we'll know why. What was mitsubishi thinking with that tiny *** cooler anyhow.
On topic though, the HKS cooler looks very nice, and nearly identicle to the Setrab fan pack unit that SSP is putting together.
Reply 0
Subscribe
