MR Cammed?
Old Nov 15, 2009 | 01:43 PM
philamthebest's Avatar
MR Cammed?
Hey guys, i just wanted to know if anyone has cammed their MR and if so how does it run and recommendations on this? I am interested how the idle is and timing?
Kelfords or cosworths? hmmmm let me know guys
thanks
Old Nov 15, 2009 | 07:38 PM
00EvoX's Avatar
I've seen a few in california, all have used the Cosworth MX1's. The gains are about 15whp in the midrange and only about 5whp over top whp. So for $900 installed plus having to get a tune after its not a whole lot of HP for the money.
Old Nov 16, 2009 | 12:33 AM
Arutha's Avatar
im running jun cams in my MR. making 422whp for the last couple of months. no problem at all with the sst. the idle is lumpy as all hell but then i am running stage 3 cams so i kind of expected it and to be honest i rather like it.
Old Nov 16, 2009 | 05:35 AM
Do you know which of the cams makes the best power, as your right, $900 and a tune isnt't worth it for 5hp
Old Nov 16, 2009 | 02:23 PM
madfast's Avatar
woah, what's the tq at the wheels? tq limiter kicking in? or SST slipping?
Old Nov 16, 2009 | 04:20 PM
Has anyone experienced the car stalling with these cams?
Old Nov 16, 2009 | 07:25 PM
00EvoX's Avatar
It seems if you do a turbo upgrade first(FP Red or Dom 2.0) the HP increases while the torque goes down and levels. If you add cams after that the scale will follow along. Someone in cali did the FP Red and got 382WHP and 320ft/lbs and then added MX1 cams and got 393whp and 332ft/lbs. But I'm sure you could go with more aggressive cams and get right about 350ft/lbs of torque if your worried about the tranny. Also you get the benefit of a higher RPM curve anywhere from 7600 to 8000.
Old Nov 16, 2009 | 07:37 PM
Arutha's Avatar
we have managed to remove the tq limiter and edit the sst programing so we can adjust gear change and ferocity to resolve the slipping issues. initially i was getting a lot of clutch slip but after reprogramming it we are all good. so yeah no slip and no torque limiter. the car was done 3 months ago now and i have been using i as a daily ever since with no problems at all.
Old Nov 16, 2009 | 09:45 PM
Hakmeister's Avatar
........................... how............... TELL US NOW OR WE WILL EAT YOUR BABIES
Old Nov 17, 2009 | 08:23 AM
You removed the tq limiter? PLease post how you managed to remove the slippage as i think most tuners will want to know this. I want to put cams in, i am getting a tranny upgrade from ssp, but ofcourse tq is always a worry...
Old Nov 17, 2009 | 12:28 PM
Arutha's Avatar
the guys that tuned my car spent a lot of time going through the sst programming. i dont pretend to know enough about it all to give you all an accurate and in depth response to how to do it.
not that any of this really helps you all as im in australia not the US lol. the man to talk to is Ryan at JustJDM if you really want to know how they did it.
Old Nov 17, 2009 | 12:53 PM
madfast's Avatar
All Aussie X SST owners, you now know what you have to do...
Old Nov 17, 2009 | 12:57 PM
malymabl97's Avatar
I have the MX1 and valve springs. It idles a little rough, but I can live with it.
The dyno chart can be view at hbspeed.com/dyno
Old Nov 17, 2009 | 04:51 PM
00EvoX's Avatar
I wanted to know what your times are if you have any. 0-60, 1/4 mile, and/or 60ft with the torque limiter removed. Thanks.
Old Nov 17, 2009 | 08:22 PM
Arutha's Avatar
i wont be doing any qtr mile drags untill i get some new clutches in the car. keep in mind im making all that power on a STOCK transmission. no clutches no cooler (the cooler is being used as a paper weight on my desk atm lol)
