Is this normal for the sst?
Old Feb 11, 2011 | 08:16 AM
Evod350z's Avatar
I have this knocking noise coming from the center console right under the shifter. Everytime its on Park and i step On the brake, it make that clicking sound. I wanted to know if its normal before i take it to the dealer. I have a 2010 SE 3k miles.
Old Feb 11, 2011 | 08:42 AM
Widoww's Avatar
This clicking noise right under the shifter boot only when in park putting into a gear? Normal
Old Feb 11, 2011 | 09:24 AM
Evod350z's Avatar
Ye when in park. Whenever you tap the brakes while the gear is on park it makes clicking noise.
Old Feb 11, 2011 | 10:00 AM
lakay888's Avatar
normal
Old Feb 11, 2011 | 02:04 PM
luvboost's Avatar
it's the shift lock release allowing you to shift from park with the brake is applied
Old Feb 14, 2011 | 03:45 PM
nhowar's Avatar
yup, brake shift interlock. try taking it out of park before it clicks.
Old Feb 14, 2011 | 05:09 PM
richardjh's Avatar
I reckon the TC-SST needs a fact sheet stuck to the sun visor. Like...
Brake Off: Pause-Clunk
Engine Off: Clunk-Whine-Clunk
Throttle On at Low Speed: Clunk
Throttle-off in high gear, low RPM: WubbaWubbaWubbaWubba
Change Up in NORMAL: Snick-pause-Clunk
Change Up in SPORT: Snick-CLUNK
Change Down: Rev-Clunk
ReverseToDrive: Whiiirrrrrrrrrrrrrr-Clunk
Transmission Info Reverse: Whirr-FastBeep-FlashingR-FastBeep-FlashingR-FastBeep-FlashingR-FastBeep-FlashingR-Clunk-SlowBeep-Finally-ReverseOK
Basically, if your Ralliart/SST-Evo isn't making noises like an old printing press, take it to the dealer and get it fixed.
Rich
Old Feb 15, 2011 | 02:46 PM
bossssman38's Avatar
Rich
This should be stickied hahaha
Old Feb 15, 2011 | 08:03 PM
kozmic27's Avatar
Rich
That is some funny ****.
Old Feb 16, 2011 | 05:41 AM
walkerkd's Avatar
Sticky!
Rich
Old Feb 16, 2011 | 05:44 AM
seanr8368's Avatar
that is pretty funny, when i back out of a spot then put it in drive i have to wait a couple secounds for it to kick in, its like o your ready to go hold on ill be with u in a sec
Old Feb 16, 2011 | 10:52 AM
nginear's Avatar
Correct me if I'm wrong but doesn't an ES model have a CVT transmission not a TC_SST? Either way it is the shift lock release the OP is hearing.
Old Feb 16, 2011 | 10:53 AM
migs647's Avatar
SE, not ES. SE is the Evo X Special Edition, which has a SST.
Old Feb 16, 2011 | 10:54 AM
nginear's Avatar
gotcha ya. I always heard the evos call MR or GSR or evo X's
Old Feb 17, 2011 | 06:20 AM
Evod350z's Avatar
oic...the SE is the best out of all of them...bwahaha
j/k...
08ev
15
Mar 13, 2012 10:29 AM
C3L1CA
13
Jun 18, 2011 03:37 PM
MICLOIV
Jun 6, 2010 08:00 PM
ejcabrera
Jan 2, 2007 11:30 AM
NRG
Aug 17, 2004 08:23 PM
