wtq limits for ssp clutch kits?
I would love to see that graph .. its either a rollercoaster .. or the dyno reads high ..
rough because you fitted something thats not computed for .. thickness ..
you can probably expect a few CELs later .. once you put power down ..
Originally Posted by ralli time
i own a ralliart and recently put in the 600hp clutch packs and i was just wonderin if it was normal for the car to drive rough when they are first put it. like a few gears kinda bang in and 3rd to 4th slips a b i only put about 100 miles on the clutches so far. i know im not an evo but im just tryin to find some answers.
Here is a chart:
Last edited by Kracka; Aug 11, 2011 at 06:08 AM. Reason: changed URL tags to IMG tags
Cobs dyno doesn't read high the chart is posted under several placed in this forum
Here is a link
http://accessecu.com/dyno/graph.php?...rgb1=000000255
Here is a link
I just took a look at the charts .. you can't hit that level ..
the gearbox will shut you down even before you hit that level .. and it has nothing to do with engine .. put it this way .. output numbers on dynos are never correct for the SSTs ..
.. this is the way the gearbox and engine interface is designed .. you can't run away from this .. no matter how you choose ..Bryan knows the SST more than any of you guys .. (other than me
Bryan does know the sst, but cobb and Tephra are the ones who're experimenting w/ it at a code level. They know more about how it works than bryan. And they've gotten good tq out of it, though they still aren't happy with where they are. Supraboy's car does make that tq, cobb's dyno is accurate (6% below DJ), and this has been verified by many. I'm going to do a back-to-back of my car on cobb then on a local DJ just to prove this point.
All of this doesn't replace the fact that supraboy's car is slow :-)
Back when I had my IX I verified Cobb's Mustang reads between a DynoDynamics and a DynoJet. Results were similar when I took my X from a DynoDynamics to Cobb's Mustang, but my X hasn't been on a DynoJet yet.
LOL yup, but, that at least shows it's within the range it should be
I can agree with Jake's (chkmgnt59) 6% claim too, that sounds about right from my findings. My IX read about 15% higher DD --> DJ, and about 10% higher DD --> M (and 6% lower DJ --> M).
Our local mustang dyno reads pretty close to our DD dyno. Another fully built X with a black just barely cracked 500whp on E85. Just saying.
But anyway, isn't this thread about wtq limits for SSP clutches? LOL. What happened here, i didn't see any mention of SSP stuff but I skipped to the 2nd page.
When you see your numbers are the same on the dynojet will you still post them?
Actually Alamo Autosports in Arlington has an AWD Dynojet. I really should go over there and throw my car on it. This Sunday however I am going to put my car on another Mustang Dyno that isnt COBBS and I will for better or worse post it here.
Im man enough to make a retraction if Im wrong about COBBS dyno.
Didn't know alamo had a DJ....
)You have me scratching my head on this one...How the the hell does the dyno know whether a car is an automatic or a manual??? You dont hook up any electronics to the cars computer... You attach a hose to read boost and a sniffer for AFR's.
