Yet another SST question.
Old Dec 5, 2012 | 09:16 PM
cheez_it33's Avatar
I know, there is a ton of these SST problems and question threads. I owned a 2006 IX and sold it about a year ago. Now I'm looking at buying a 2008 X MR. Went to the dealership and test drove it today. Car was super smooth with shifts and rode great. The only problem it has is, it will not switch from normal to sport mode or s-sport mode. Could this be a tuning issue, or could a relay not be sending the proper signal from the switch to the transmission control unit? I can put it in manual mode by moving the shifter to the left and use the padels to shift, it just won't go from normal/sport/s-sport like it should with the switch. I hope this isn't confusing. I also hope this hasn't been covered before. I swear I've looked at almost all the SST trouble threads. Thanks in advance for any info anyone has. Here is a link to the car I've been looking at.
http://www.bigjoeauto.com/used/Mitsu...03836f92cf.htm
Old Dec 5, 2012 | 09:23 PM
cheez_it33's Avatar
Here is the VIN as well. Just in case someone knows the previous owner. Maybe I can get some more info on the car other than the Carfax. The vehicle is originally from Maryland. JA3AW56VX8U050880.
Old Dec 12, 2012 | 12:58 PM
Supraboy1's Avatar
Its possible that a drink was spilled right on the switch and shorted it out. I would make them send it to a local Mitsu dealership as its under warranty. Hopefully its an easy fix.
Old Dec 12, 2012 | 01:37 PM
trick3d's Avatar
i would not buy that one at all. Why would you even consider it? the SST in normal is boring.
Old Dec 12, 2012 | 02:42 PM
BuckeyeMatt's Avatar
I'd error on the side of caution and stay away
sumguy11
Mitsubishi TC-SST Discussion
Feb 20, 2015 09:18 AM
RS200Z
Jan 20, 2015 02:39 PM
1711902090
17
Sep 21, 2013 06:30 PM
smgevo
18
Aug 31, 2009 05:15 PM
dklau33
39
Nov 26, 2007 05:20 PM
