TC-SST Fluid Change - Filter Question
We sell the OEM SST Fluid http://www.awdmotorsports.com/product_p/c0002610.htm PM ME
I am glad I changed my filter myself on my Ralliart because I got to see first hand that the O-Ring was in bad shape and was leaking some oil. The best advice I can give you is buy quality oil and a good filter and do it yourself. (1) So you don’t get raped on the labor to change the oil (learned this the hard way), and (2) So you know first hand the condition of your filter, drain plugs, oil volume, and etc.
You can only drain about 5.7 - 6L without flushing it. You will need 2 X 4L, but you will obviously have some leftover for next time.
I'd rather do the flush then. Makes sense to do so. I'll research some. Everyone seems to have their own way of doing it.
Once it is time to buy a home, the garage will be top consideration though.
Definitely recommend changing the filter, paper or stainless, doesn't matter. Just get it done. Like Kozmic said, the tranny is expensive (though down from the $10k years), It's worth the ~$100 for just the peace of mind.
1999VR-4EVO
32
Apr 6, 2018 05:43 AM
maramaralula
Mitsubishi TC-SST Discussion
Mar 27, 2014 11:03 PM
SmurfZilla
13
Oct 6, 2012 01:29 PM
