Evo X mr sst '09 stuck in 2nd 4th and 6th
Old May 11, 2019 | 04:03 AM
DWEvoX's Avatar
This problem is appearing quite often: even while i'm driving normally (law speed) sometimes the information display turned yellow and "SERVICE REQUIRED" came up. From that point forward the car would only shift between gears 2, 4 and 6. I could downshift in 1st but the car *beeep* like an error, and if i try to shift in R, the R on the information display start blinking and the gear doesn't work.
If i restart the car normally the problem disappear.
More rare is the case that a gear (it happened in 1st) "disengage" and instead of moving the car would just rev in place.
I noticed a little oil leak on the garage's floor (a stain around 2inch x 2inch maybe?) in the front of the car.
The car was used like 2 days in the last 3/4 years for personal reasons, and i did the classic motor oil and filters change one year ago.
It has around 50k miles
Old May 15, 2019 | 01:39 AM
DWEvoX's Avatar
I got the following codes:
P0716
P1844 - Shift fork 3
P0701 - EEPROM malfunction
Old Apr 13, 2021 | 01:31 PM
pldenys's Avatar
Any updates
Hi, I was wondering if you have managed to get this resolved and if you could share what the solution was. I'm having similar issues with a 2013 Ralliart?
Old Nov 28, 2022 | 01:21 PM
DWEvoX's Avatar
Sorry for the terribly late reply, but unfortunately not, car still parked in box because I had no time to work on it.
Did you by any chance solved the issue?
Old Nov 28, 2022 | 02:38 PM
Biggiesacks's Avatar
Sounds like a shift fork magnet (Very common). Unfortunately the trans needs to come out to make a repair.
It could be something else though.
What's the maintenance history for the trans?
Old Nov 28, 2022 | 11:58 PM
deylag's Avatar
If it still under warranty or aftermarket warranty then you can take it to the dealership and they can replace the transmission. The DTC is covered under a recall.
Boostin Perform
Midwest Region
Feb 12, 2020 08:00 AM
evochick88
Aug 23, 2014 06:16 PM
MichRA09
Dec 26, 2010 02:01 PM
AZ EVO IX MR
Sep 11, 2006 07:45 PM
MR
Dec 3, 2004 01:01 PM
