MR Shifter Console
MR Shifter Console
I'd like to swap my 5sp trim for the MR's. I do not want the ashtray, so I only need the console cover and shift boot. I'm going to make my own sticker.
Does the shift boot come attached to the plastic ring that screws into the console cover?
So, it looks like I only need...
6 Speed M/T Console Trim
Gearshift Lever Cover (Shift Boot)
Gearshift Lever Panel
What are these for?
Gearshift Lever Cover Screws
Thank you ahead of time.
What are these for?
there is no ring on the 6 speed cover and the boot is differnt as it snaps/wont fit on the 5 speed lever unless you like seeing your silver rod and the 5spd boot is too small for the 6 speed covers hole. Its also not a "sticker" its actually part of the cover itself with like a clear gel coating over it.
Thanks for the input. Is that small piece at the top of the boot (on 6sp) actually part of the boot? Is this what you're referring to?
So bottom line, it can't be done?
Here is a link and a break down of all the parts. Im also still doing free ground shipping through the end of the month.
Shifter Boot - MN124950XA
"MR" Badge For Console - 8011A017
Gearshift Panel - 8015A001HA
Screws - MB409435 (qty. 5)
http://www.mitsubishiparts.net/cart/...5*5+MN124950XA
From: Why do they always call the Evo the Dark Side?
(my panel is scratched)
thanks
john
Mcstikman
Mar 17, 2024 09:51 AM
Cyrax91
Nov 21, 2016 07:20 AM
whealy
Evo X How Tos / Installations
Jul 8, 2010 05:52 PM
8015a001ha, badge, boot, console, evo, evom, forum, mitsubishi, mn124950xa, mr, panel, ring, shift, shifter
