Advantage to 18" wheels?
Old Dec 6, 2004 | 12:59 PM
chrisw's Avatar
Originally Posted by gestalt
I am looking to upgrade wheels and I was wondering if there is an advantage to 18" wheels that outweigh the added weight. I do about 4 track events and about 10 autocrosses a year. Any advice would be appreciated.
Get the lightest wheel you can afford. I would also recommend a 17" rim over the 18" inch rims becasue of the tire costs. 17" race rubber is generally more available in the sizes that fit the EVO.
When selecting wheels, weight and wheel strength should be your primary concern, not rim diameter.
Old Dec 6, 2004 | 04:06 PM
donour's Avatar
Originally Posted by 00R101
If you don't need stock size then the SSR Competition is lighter still.
I'm , but you can get 17" (stock) SSR competitions -- quite light indeed.
d
Old Dec 6, 2004 | 08:25 PM
g6civcx's Avatar
Here's the key to picking a wheel size: pick your brakes first.
After you have selected your brakes, pick the smallest wheel size that will fit over the brakes.
Then from those that will fit, get the lightest one and strongest one.
Here's another monkey wrench: wider wheels can fit wider tyres, but also weigh more.
Pick your poison
Old Dec 7, 2004 | 01:21 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
d
but according to the SCCA rule book, the wheel's WIDTH and OFFSET can not vary by more than 1/4 inch from stock. Since these guys are talking about A- Stock autocross racing, the question is are the width and offset the same as well? Not just diameter.
Old Dec 7, 2004 | 01:23 AM
Moderator
Bomb Squad Unit #02
Originally Posted by SOF
Nope, try again.
Bigger wheels means bigger tires which means bigger grip and bigger heat dissipation. I don't know what kind of racing you do, but for most people that's pretty important.
Define bigger. I can get you a set of 18" wheels that are 7" wide, would that grip better than a set of 17x9 rims (assuming appropriately sized tires)? I think you meant that wider rims can get wider rubber. Not worrying about diameter in that case.
Old Dec 7, 2004 | 08:22 PM
SOF's Avatar
SOF
Yea I wasn't clear. "Generally" as you go up in diameter you go up in width too. And "generally" as you go up in diameter you go up in tire diameter as well, which means more rubber still.
Old Dec 8, 2004 | 12:08 AM
Moderator
Bomb Squad Unit #02
I can see that generalization, but racing in SCCA for the past 6 years has shown me that there is no shortage of 15x8, 16x10, and even 13x12 rims either (13x12 looks and performs great on a Dodge Neon, btw). Most "bling" wheel packages for inching up, however, are 7" wide. Good thing racers know better.
Old Dec 8, 2004 | 12:58 PM
Dom's Avatar
Dom
not really
on my RX-7 I went from 18' to 16' for 1/4 mile and 17' for track both wider
than the 18'
Old Dec 8, 2004 | 05:22 PM
SOF's Avatar
SOF
I don't waste my time on bling wheels. Most race wheels go up in width as you go up in diameter.
Uscbryan
16
Jan 14, 2016 11:45 AM
BTBean
Outlander Sport
32
Nov 20, 2014 03:46 PM
XcreatonX
Jan 6, 2012 09:37 AM
BoostLover99
Mar 8, 2008 06:42 AM
exacc
Feb 26, 2008 03:53 PM
