STU & Adding a front LSD to an 03 EVO?
Old May 26, 2005 | 01:15 PM
tweekscratch's Avatar
Apparently it is ok to add an front LSD to an EVO in ESP class. Is it legal for STU?
Also, what is the approximate cost of the Quaife LSD? And is it an install I should try on my own or would I be better off paying a pro?
Old May 26, 2005 | 01:20 PM
chrisw's Avatar
No not legal for STU because you already have a rear LSD.
Your only allowed to add one LSD diff if the car does not have one already.
For example, the base model eagle talon tsi AWD came with no rear LSD (I know, I owned one of these models) With the current STX/STU rules, I could upgrade one single diff... When I got the WRX, no diff options were allowed because the car already came with a factory rear diff.
The quaife will run you about ~$1500, it's possible to do the install yourself.
Old May 26, 2005 | 01:27 PM
That is a bummer. I got to ride in an 03 w/ a front LSD. It was freaking amazing. The driver isn't half bad, but I'm pretty sure having the front LSD helped.
Maybe I'll save the $1500 and trade in the 03 for an 05.......
Old May 26, 2005 | 01:29 PM
00R101's Avatar
Update/Backdate rule for SP applies to ST as well IF the 2 models are on the same line in the rules AND IF you make all the changes necessary to convery one model to another.
Here are 2 made up examples
Example 1 - Let's say that a 1991 BMW 325 could be had with an optional LSD. You own a 1990 BMW 325 which appears on the same line in the rulebook and did not have an LSD as an option. You can install the LSD from a 1991 BMW 325 in your car.
Example 2 - Let's say a 1997 Miata was avaible with a 6 speed tranny as part of the Sport Package (which also included bigger brakes, leather seats and a faster steering ratio) If you had a non-sport package Miata, you COULD NOT install the 6 speed in your car unless you also added the leather and the brakes.
So, in the case of the '03 Evo, my question is was the LSD available as a stand-alone option in '04 or '05 (the answer is no). So, to add the LSD you could:
1) Convert your '03 Evo to an '04 RS (remove the ABS, remove the trunk interior, add the rear performance bar, remove the power windows, power doorlocks, HID headlights, foglights, remote control light levelers) - You are not going to do this option.
or
2) Convert your '03 Evo to an '05 GSR. (add the LSD and the new Turbo inlet stuff, remove the HIDs)
Either way it would be cheaper to buy an '05
regards,
alan
Old May 26, 2005 | 02:40 PM
DaWorstPlaya's Avatar
I believe allowing exchange between year models is allowed in SP but not in ST. In stock and STU/STX you can change between models of the same year, provided you do a complete conversion. 04 EVO to 04 EVO RS but since there were no RS models in 03 you can't do a complete conversion .... that is what I remember reading ...
Old May 26, 2005 | 06:43 PM
headache. Sound like I'll just wait for a IX and step up to that. Which means I'll continue training w/ this car, but not install the coil overs. Luckily I can pull the XEDE and send the ECU in for a flash when I sell the 03.
Old May 27, 2005 | 04:05 AM
jwtodd60's Avatar
You're mixing apples and oranges here a little bit, at least if I am understanding you correctly. In SP, you don't have to make all the changes to convert one model to another. E.g., if you want to run your Evo MR wingless or without the trunk liner in ESP, you can do that without having to swap out the MR's 6 speed and power windows/locks for the RS's 5 speed and manual windows/locks. On the other hand, if you were running in stock class and wanted to run your MR wingless, etc., you would have to make all of the changes necessary to convert it to an RS of the same model year. As I understand it, ST* originally allowed update/backdate like SP, but that allowance was dropped (the term Frakencivic comes to mind). The model conversion option still exists though as that is inherited from the stock class rules.
JW
Old May 27, 2005 | 08:10 AM
chrisw's Avatar
Like jwtodd60 points out, there is no update/backdate rules in ST.
I would still go with the coilovers, you can gain alot in STU, and when you decide that it's cheaper to run on race tires, you can install the LSD and jump in to ESP.
Old May 29, 2005 | 08:16 PM
After taking two days of evolution school, I'm a bit less concerned about the front LSD now. I think adding good tires (going to stick with Kumho MXs) and a great set of coil overs will allow me to start mopping up in my region. I'll give that setup a year or two and then move over to a IX after Berry and Daddio figure out the problems with it.
As usual: the advice on this board is great.
Old May 29, 2005 | 11:47 PM
SS RX7 r2's Avatar
Originally Posted by tweekscratch
... after Berry and Daddio figure out the problems with it.
Is Tom? Berry is getting an Evo?
Top CSPer George Doganis has been talking to me about getting an Evo for the past year or so. He drove our STU RS today and had an incredibly fast raw time in it.
Old May 30, 2005 | 06:33 AM
I'm refering to a person here in Dallas who drives an 03 in ESP. He is kicking *** and making all the Subbie drivers wake up and pay attention.
Old May 31, 2005 | 05:15 AM
KC's Avatar
KC
Just to re-iterate... there is no UD/BD in ST. That was done away with 2 years ago to prevent frankencivics.
It falls back on the stock way of 'package conversion'. You'd have to essentially make your car exactly the same as whatever car you want the parts from... every single part that is different must be put in.
--kC
Old May 31, 2005 | 05:27 AM
At this point I have decided to stick w/ the '03 w/o a front LSD. I'll buy a IX in a couple of years. That way I should get front LSD w/ ACD too. Hopefully I'll be good enough that it won't matter.
Old May 31, 2005 | 12:59 PM
SS RX7 r2's Avatar
Hi tweekscratch,
I think I heard about M. Madarash in ESP competing against him?
Are you planning to go to Topeka this Sept? I wish I lived in Texas - just a short drive up
Anyone interested in the STU class should grab a codriver and enter the finals this year - it's a big party. If this provisional class fails to get 25 drivers entered, STU will most likely be dropped in the future everywhere.
Maybe KC can elaborate further?
Old Jun 1, 2005 | 04:49 AM
Yes, Speed Racer (Madarash) is having a hell of a time keeping Racer X off the podium. What is great about it is both are fantastic drivers. Watching them driver is like watching a genius at work, they literally make their cars dance.
I got to ride in Berry's car which is what got me thinking about the front LSD.
Unfortunately I don't have nationals on my calendar and it is a bit late for me to add it. I have a feeling that they will get 25 drivers. Dallas alone has 5 - 10 STU drivers regularly showing up. Several of them will be going to nationals.
I'll add nationals to my calendar for next year.
