tire pressure for road course
Old May 31, 2005 | 07:00 PM
nothere's Avatar
so no one is using the wear pointers on the sidewall for tuning their tire pressure?
Old May 31, 2005 | 08:05 PM
racerjon1's Avatar
I use how the tire wears but not any one point... I use a combination of rollover, and how the treadblocks wear on the edges, including wear pointers.
Baseline, i start 4-5 psi higher than stock, then go up based on the above, plus feel, and temps. (temps is the Best way to do it, also for setting alignment)
I will then ballance it with the rear pressures, and then fine tune the front as needed.
Jon K
www.seat-time.com
Old May 31, 2005 | 08:12 PM
tweakdsm's Avatar
on the door says: 32 Front, 29 Rear.
Old Jun 1, 2005 | 03:15 AM
Kayaalp's Avatar
Errr...OK. But we're talking about track use here. Those are just the recommendations for normal street use (and they're very conservative, BTW). It's not a bad starting point, but you can't just blindly follow the manufacturer's suggested pressures and expect them to work great on the track.
Emre
