Weigth reduction mods.. what woks for the evo...
Old Sep 23, 2005 | 06:20 PM
  #31
Kayaalp's Avatar
Originally Posted by fromWRXtoEVO
If you think by removing 50LBS is going to make much of a difference think twice, a good tunning could make more than what you expect from weight reduction, combining both is even better but do you really want to removed the HID lights? do you want to ride in a car where you have to roll the windows manually or live in Tucson and no having A/C?
BTW, on a track car, you never use your headlights unless you're doing a night enduro (in which case the stock lights aren't good enough anyway). Nor do you care about power windows (or power anything, really). And you're sure as hell not going to use your a/c. on the track!
On my track car (a BMW), I've pulled out the whole a/c system. Not only does it save a massive amount of weight right at the front of the car, but it also makes service easier (easier to get to the oil filter, etc.).
Please note that this was posted in the motorsports section...not show-n-shine. This guy is asking about modifications for the track...not the strip.
Emre
Old Sep 23, 2005 | 07:20 PM
  #32
meanmud's Avatar
Emre,
I look at shaving weight off of the Evo like this:
10lbs. off the front = you need to take 10lbs off the rear; Even though the Evo is 60/40, it is set-up accordingly??? It isn't luck that a 60/40 car handles so aggressively - right?
Old Sep 23, 2005 | 07:48 PM
  #33
Kayaalp's Avatar
Originally Posted by meanmud
Emre,
Lol. No way. The Evo handles well despite it's inherent imbalance. It's not like Mitsu engineers set out to design a front-heavy car. It's a compromise.
I've been tracking cars for years. Believe me, if you could balance the car better, the Evo would be unstoppable.
Emre
Old Sep 23, 2005 | 09:51 PM
  #34
Richard EVO's Avatar
The only way to meaningfully reduce weight in an EVO is carbon fiber body panels. I don't mean just hood and trunk, that won't do much. Robi's car has carbon fiber doors, and I would think carbon fiber quarter panels would help to. They are expensive and fragile. One time at Calif. Speedway on a windy day I was checking out Robi's car, and I left a door open as I looked inside. He said, "be careful, the wind will blow that door right off." I don't think he was kidding. The EVO is inherently a heavy car, with the awd system and a tub that weighs 700 lbs. Compare that to the Elise, it's tub weighs only 150 lbs. An EVO is built like a tank. Consider adding horsepower instead of trying to shed lots of weight.
Old Sep 23, 2005 | 09:52 PM
  #35
joeymia's Avatar
how much weight do you think the stock headunit along with all speakers weigh? I was actually considering removing mine because I never even listen to it... Besides with exhaust being loud as **** I can't hear anything!
Old Oct 5, 2005 | 08:57 PM
  #36
Vishnu_Evo8's Avatar
i just got my ac removed and i took of my front beam.. total weight savings was like 51 lbs!!! im kinda pissed i wish it was more.. but the benefits will be pretty decent. all the weight was on the very front of the car... and without the condenser for the ac, i will get much better cooling for the radiator, not to mention the fact that the ac pulley is completely gone. i think im goin to try to take off the rear wiper system and the electronics for it.. more to come.
Old Oct 5, 2005 | 09:22 PM
  #37
vletnguyen's Avatar
sorry little off topic...
if anyone is removing their power steering . i would like to buy it. my pully is bent.
thanks. and please pm me.
Old Oct 5, 2005 | 10:11 PM
  #38
this may be a dumb question, but is there anyway to get rid of a sun roof other than buying an mr roof?
Old Oct 5, 2005 | 10:19 PM
  #39
Uuuhhh, don't get a sunroof in the first place.
Re: 51 lb. weight reduction for a/c and beam. That's a nice reduction. The only single component you can remove to save that much weight is to find a driver who weighs 52 lbs. less than you do. Or if you are fat, lose 52 lbs. Don't complain, that's a good result.
Old Oct 6, 2005 | 03:13 AM
  #40
meanmud's Avatar
Now - how about the rear crash beam?
Old Oct 6, 2005 | 07:53 AM
  #41
Mikey52's Avatar
Im sure you can remove the assembly and all its parts then have a panel welded in place (and the roof painted). Ive seen it done on BMW's and I assume the Evo is no different. It's all about how far you're willing to go to shed a few pounds.
Old Oct 7, 2005 | 11:33 AM
  #42
nils_work's Avatar
power steering is your friend, dont get rid of it.
n
Old Oct 7, 2005 | 11:56 AM
  #43
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
I have done all the weight removal so far such as a/c , seatbelts, suspension , wheels and tires, no moonroof ( you can order a stock roof skin without the moonroof for around $350-$400 or the aluminum MR /RS skin for around $800ish and cut out the old one and weld that in), nothing in the trunk, all sound deadener removed and carpet padding and airbag (replaced with sparco wheel with quick release). I also swapped the recaro seats for sparcos right now but my Bride Vios super low max seats should be here soon.
https://www.evolutionm.net/forums/sh...1&postcount=28
Old Oct 7, 2005 | 04:34 PM
  #44
jid2's Avatar
You can't weld in a MR roof panel. It's Aluminum, the Body is steel. Mitsubishi rivits it in with a special seal. It's actually pretty trick, so don't think you can just put an MR roof on a standard Evo and not have it leak.
You can weld in panel, that's what all the race shops do to cars with sun roofs.
Old Oct 7, 2005 | 08:13 PM
  #45
992gnt's Avatar
