ESP/BSP AutoX Setup n Some Track Days
Old Dec 21, 2005 | 09:36 AM
chmodlf's Avatar
Originally Posted by ratt_finkel
SP/ Street Prepared also allows the elimination of Cats. You can also do Update/backdate. Which means if you have an 03, you can upgrade to the 05 front diff.
Or like what a lot of Domestic guys do, take a stripped down V-6 version and throw in the V-8. Read the rule book, there is ALOT you can do in SP.
I got rid of my open diff on my 03. I purchased a 05 helical from TRE. $1000 vs. $1500 Quaife from RRE. Unless you are making huge power the cheaper diff is more than adequate.
The LSD makes a HUGE difference for our power on understeer.
Old Dec 21, 2005 | 09:52 AM
chrisw's Avatar
Originally Posted by DaWorstPlaya
The EVO has been bumped into BSP from ESP, because it dominated in ESP ....
The EVO is allowed in the following classes:
1. AS (A Stock)
2. STU (street touring unlimited)
3. BSP (B street prepared)
4. SM (Street Modified)
Everything that is allowed in a lower class is allowed in a higher class + more ...
Warrtalon: what mods you have described are for AS only ...
Power mods that are legal for BSP are what is allowed in STU + more:
1. Turbo back exhaust with cat (not 5 inches away from stock cat location).
2. Headers
3. Hoses
4. Intake
5. Intercooler
6. Fuel injectors
7. Fuel pump
8. Boost control is finally being allowed in SP category in 2006
9. Nothing inside the engine can be touched ....
There are more but I am not concerned with the SP classes ...
You can download the Solo handbook from
www.scca.org/Solo/Index.asp?IdS=003D84-DD12F70&x=050|070&~=
For suspension, it seems like the EVO that took 1st place in this years SOLO2 used Ohlins coilovers ... Alot of EVO track racers use the Ohlins and love them ....
Alignment you will want to play around with, start with the following and adjust as you see fit:
1. 3 deg -ve camber in the front
2. 1.5 deg -ve camber in the rear
3. 0 toe front and rear
4. Max castor setting the camber plates allow ...
For tires you will want some kind of R-compound tires in the SP class for eg: Kumho Victoracer, Kumho V710, Hoosier A3S05 ... etc
Wheels of any diameter, width or offset are permitted. Wheel spacer are also permitted.
you are close on the specs...
for SP (ESP, BSP) you are allowed the following
unrestricted mods:
intake, intercooler (don't cut the bumper beam), fuel system, ignition, water injection, boost controls, exhaust. clutch and flywheel are unrestricted.
restricted mods
no changes are allowed for the turbo, wastegate. You can update/backdate the turbo only if you do a full engine swap. No cams or cam gears (yet, there is a proposal on the table to allow cam gears).
You can't change the suspension points, or replace the suspension bushings with metal replacements
No changes to the brake calipers. you can run stock replacement rotors that are slotted or drilled, but you can not change the dimensions of the rotor. Brake pads are unrestricted.
In Street touring (STU)
you can replace the exhaust, but must keep a Cat in place. As the rules apply to the EVO, it's an no brainer, just put one in where it belongs.
No intake changes, no intercooler changes, no fuel system changes, no changes to the stock boost control unit, wastegate, etc...
restricted to 245 sized tire on an 8" rim with a tread wear rating of 150 or above.
brake rotors calipers can be updated with aftermarket equivelents. Not sure about the multi-peice rotors.
You have to run the stock clutch and flywheel.
Old Dec 21, 2005 | 10:04 AM
DaWorstPlaya's Avatar
Are you sure about the stock clutch? I thought that since clutches are wear items they can be replaced with any other brand of clutch. I was under the impression this was true for AS, thus true for every higher class ...
Old Dec 21, 2005 | 12:34 PM
ratt_finkel's Avatar
Actually, you seem to be quoting some STX rules and stock rules.
In all ST classes, the intake is free up to the throttle body, you can change fuel and ignition timing, But no BOOST control.
STU
Wheels are unlimited in size. AWD cars are limited to 245's. FWD and RWD can run up to 275's.
STX says you can use up to an 8" rim and all cars are limited to 245's.
STS and STS2 are limited to 7.5" rims and 225's.
For Exhaust, as long as the stock cat is in its factory location you can change everything else. Stock and ST classes require factory clutches and flywheels.
The rule book is online, it's all there.
www.scca.com
Old Dec 21, 2005 | 01:29 PM
chrisw's Avatar
positive
Old Dec 22, 2005 | 06:56 PM
KC's Avatar
KC
Going to fix a few things here as far as STU rules...
Corrected:
In all ST classes, the intake is free up to the throttle body for N/A cars and up to the compressor inlet on Turbo/Supercharged cars, you can change fuel and ignition timing, But no BOOST control.
Corrected:
In STS.. you no touch cat period. Bad monkey! In STX/STU There must be at least one cat (can be hi-flow) where the entrance of this replacement cat is no further than 6" away from the exit location of the old stock cat.
What does this mean? You don't have to have it exactly where the stock cat is. You can even move it downstream more and have a high-flow cat. You can put it anywhere in the system (even 2 feet before where the old stock cat was) as long as it's no farther than 6" past the exit of where the old cat used to be.
--kC
Old Dec 22, 2005 | 07:04 PM
KC's Avatar
KC
It can be any brand that is correct, but it has to be what is considered equivalent to a stock clutch. Like, no 3000lb clutches if the stock was 2200lbs. *cough* (SOmething that is illegal: http://www.roadraceengineering.com/evo/nonameclutch.htm) *cough*
Old Dec 22, 2005 | 07:20 PM
Slowride's Avatar
Not exactly. It had:
Works front camber plates
Works rear upper mounts
Custom-valved Ohlins dampeners
Eibach springs
Buschur rear swaybar
Works urethane bushings
DC Sports Titanium rear strutbar
Old Dec 22, 2005 | 07:42 PM
chrisw's Avatar
STU
www.scca.com
yeah, I don't follow the ST rules much, I have modded my EVO past the limits of ST, probably end up in SM for next year.
Old Dec 28, 2005 | 11:26 AM
Erik@MIL.SPEC's Avatar
So is a lower intercooler pipe allowed for BSP?
And is removing the stock undertray allowed?
Old Dec 28, 2005 | 07:12 PM
chrisw's Avatar
yes, the intercooler system is totally unrestricted.
I think you can remove the undertray, but think of what would happen if a cone were to get stuck in there at around 40-50 mph... It could literally rip the oil filter off the engine.
Old Dec 28, 2005 | 07:25 PM
Yes, but I have a Nisei unit which would require me to trim the stock undertray, which if I understand things correctly, isn't allowed. Correct? Thanks though, didn't think about the cone
What about coatings like SwainTech or JetHot?
I'm getting pretty excited, because it looks like my car will be able to run BSP.
Old Dec 28, 2005 | 07:30 PM
whitet777's Avatar
The intercooler is unrestricted in BSP, but I am not sure about the piping. You be the judge. Here is the verbage out of the 2006 rules:
3. As utilized only on engines originally equipped with forced
induction, induction charge heat exchangers (known as “intercoolers”
or “charge air coolers (CACs)”) are unrestricted in
size and configuration. Air-to-air CACs and radiators for airto-
liquid CACs must be cooled only by the atmosphere, except
for standard parts. Body panels, fascias, or structural
members may not be cut or altered to facilitate CAC installation.
Old Dec 28, 2005 | 07:57 PM
Ok, I am going to hedge a guess and say the undertray does not qualify as a body panel (fenders), fascia (front bumper) or structuaral members. Anyone agree?
Old Dec 28, 2005 | 08:27 PM
Warrtalon's Avatar
Atlvalet, I highly doubt anyone will care about the plastic undertray. However, I highly doubt we can even be close to competitive in BSP without a fully-dedicated, perfectly-setup suspension and wheel/tire combo.
Last year's ESP top 3 at Nationals were all Evos, but they would have finished 7th, 8th, and 9th in BSP.
