Dynoflash 2-step "launch control" BSP legal?
Old Feb 25, 2006 | 03:50 PM
kekek's Avatar
I will be getting my car tuned by Al in the coming month. Debating whether or not I think the 2 step launch control is SP legal.
I know there are no hardware changes, only code changes in the software. Supposed to build around 10-12 psi boost, which will be rough on the drivetrain with 285's. Since all the fuel and timing stuff is open and alternate ECU's can be run, I would think it's legal. Then again he must be adding a line of code in the ECU to reference the different sensors necessary to make the 2 step work (clutch switch, rpm, speedo sensor).
Anyone have any opinions?
Old Feb 27, 2006 | 05:13 AM
kekek's Avatar
no takers huh?
Old Feb 27, 2006 | 08:39 AM
ratt_finkel's Avatar
As long as it's done within the parameters of the rule, then it is legal. I know some people have argued that even anti-lag could be done within the SP ruleset. Might want to try asking the SP forum at sccaforums.com. I'm not intimate enough with the class to know for sure.
silversurferix
Aug 30, 2013 04:53 PM
RalliAaron
May 23, 2012 10:16 AM
Jedi_Gill
Jan 24, 2008 03:28 PM
sekula
Sep 13, 2007 01:47 PM
wspy
31
May 15, 2005 08:42 PM
