400whp + auto-x car?
I said that, Randy. TQ is far more important than HP, because you spend more time powering out of turns than you do on long straights. Some courses are longer than others, but I actually have yet to use 3rd gear. I utilize my huge torque constantly, though.
I'm really surprised by your tone.
I told you that I have seen multiple cases of differing power delivery based on 264s vs 272s. Maybe there was no low end spoolup difference vs stock cams, but I'm not talking about spoolup . . .
These were facts as tested on multiple dynos with multiple cars on multiple occasions. I don't know why you discredit those facts as just being my "beliefs," especially when they are the commonly-held beliefs of most anyone who discusses and chooses between different cam setups. I don't know what to tell ya, man, but that's what I've seen and that's what many many MANY other people have seen. I trust Dave with anything on my car, but I haven't seen dynograph overlays to show the exact torque profiles of different cam durations on the same car - I couldn't read through all 50 pages of that thread. Do such overlays exist?
I did read every page of the thread and I even printed the entire thing to keep as a reference quide as to how much power each piece in his mod-path makes and what combo of supporting mods is necessary. If you have not read the whole thing I think it is something every EVO owner should read.
FWIW, I make full boost (21psi) well under 3000 rpms on the stock turbo with 280's.
EVOlutionary
I've tried stock, 264, 280 and I can tell you that there are differences in spool up between them FOR SURE! That's why companies offers different specs. I've been testing out some cams last few weeks. For autox, I personally won't go anything bigger than 264.
you could play with cam gears and get similar effects... the difference in durations are for people that don't wanna test cam gears, tho the overall durations sometimes make things better or worse depending on waht you're looking to do.
No, i don't have the resources Dave has, so it makes more sense that his findings are more valid than my "beliefs," but at the many Dyno Days I've coordinated and run, the 272 cars had much different powerbands than the 264 cars. It was a pretty obvious difference where the power curves would criss-cross when overlayed. The 264 car would have more area under the curve until it got crossed by the 272 power curve at higher rpm. From there up, the 272s had more area under the curve. I haven't seen 280s in person, but it would stand to reason that they would be more severe than 272s.
Originally Posted by ldstang50
I make full boost on on my stock 9.8 before 3000rpm. But I also have a built head, oversized valves, pistons and rods
I'll have to dig out my last dyno graph. I was partially tuned at Mach V about a month ago. I can look around. I'm in the process of moving and then getting sent to Camp Lejeune. I'll see what I can't do.
Clay, you said the it was obvious where the power curves criss cross was different with each cam. Are you talking about where the torque and hp curve cross at? Thats a 5252 constant, or so I thought. I'm assuming what you meant is where the peak trq and HP come in at and how flat the curves are, correct?
Originally Posted by trinydex
he is talkin' about the overlayed graphs crossing each other because the 264 makes more power down low but then flattens out sooner up top (where the 272s will cross over the 264 map)
If I can't find it, I'll talk to Dan at Mach V to see if he can post it.
I think my biggest thing is my ported/polished head, larger valves and built bottom end. My pistons are slightly lower compression
Originally Posted by razorlab
You have a boost vs. rpm log chart to back that claim up? Unless you stuck a T25 on your evo..
EVOlutionary
I'll log one for you this weekend. Do you have AEMLOG to open the file and read it?
