Question for guys that change tires at the track
Old Jun 25, 2006 | 03:28 PM
KZEVO's Avatar
thanks for all the replies...very useful info.
Old Jun 25, 2006 | 03:30 PM
RazorLab's Avatar
Originally Posted by chronohunter
http://cgi.ebay.com/V28-Milwaukee-1-...QQcmdZViewItem
these are both their respective best in category, you can get cheaper stuff (but the you would have settled for a STi and not bought an EVO )
That's a pretty good price for that milwaukee.
Old Jun 25, 2006 | 06:29 PM
mayhem's Avatar
Cordless impact is your friend!
Old Jun 28, 2006 | 09:27 AM
Czubaka's Avatar
Get a good torque wrench such as this one:
http://www.procarestores.com/product...s_id=006070120
Where did you buy this torque wrench from? Thx!
Old Jun 28, 2006 | 09:34 AM
TxEvo8's Avatar
+1, the time it saves is remarkable!
Old Jun 29, 2006 | 12:53 PM
cityhugo's Avatar
yes they do, i am 100% sure, u just turn the knok bethind the connector
Originally Posted by KZEVO
i do that, but even with a cross wrench it's still a pain if the lugs are torqued too tight which happens when shops use impact guns. i'm just wondering if there's a tool out there that can make it easy to take lug nuts off.
I borrowed a torque wrench from someone at the track that you could use both ways, but forgot to ask the brand. I went to sears to get one from craftsman, but apparantly they don't make one that can go anticlock wise (ie to loosen)
thanks
Old Jun 30, 2006 | 11:19 AM
Richard EVO's Avatar
If you are having that much trouble getting your lug nuts off, your are torqueing them too much in the first place. 75 lbs. is fine. As far as I know, almost all torque wrenches and impact wrench are reversible and go in both directions.
Old Jun 30, 2006 | 11:24 AM
vboy425's Avatar
I use my 1/2" breaker bar, then lift one side, zip 'em off with the impact gun, then hand thread them back on, zip' em all the way on with the impact gun, then torque to 80-81 ft-lbs with my 1/2" torque wrench. It should be very very easy to loosen lugnuts if they are properly torqued. 80 ft-lbs is light enough to loosen them even if the wheel is off the ground and spinning freely.
Yes, my torque wrench is usable in either direction, but I don't use it to loosen the lugs.
exactly what he said, but if it's really hot it will hard to take it off. so let it cool down or you going to screw up the thread.
Old Jun 30, 2006 | 11:28 AM
mayhem's Avatar
True, but I wouldn't recommend breaking lugs loose with a torque wrench. Get a breaker arm, tire iron or impact.
I used to have issues breaking my stock lugs free, but later I figured out that they were galling the hell out of my studs and locking up with the metal debris. I bought some new non-oem lugs and haven't had the problem since.
Old Jun 30, 2006 | 01:45 PM
Warrtalon's Avatar
Btw, I also find that using the ARP wheel studs makes things easier when in combination with 19mm open-ended lug nuts and an impact gun. I absolutely love my long ARP studs.
ZeRoMaX
Nov 7, 2014 01:02 PM
TWM Performance
Evo X How Tos / Installations
Sep 12, 2013 09:07 PM
trinydex
Mar 29, 2007 05:40 PM
atilla
12
Jan 10, 2007 08:27 AM
zeus1
Nov 20, 2006 02:49 PM
