Tranny Fluid
Tranny Fluid
How often you change your transmission and diff fluid? Which brand do you used? Have anyone tried Motul MOTYLGEAR 75W90 SYNTHETIC BLEND GEARBOX OIL?
After every track event. I use the stock Mits Fluids (transfer case and rear LSD use the DiaQueen LSD oil (part # 3775610), the tranny uses the DiaQueen 75W85 (part # MZ313376). No experience with the Motul. Let me know if you decide to use it and what you think.
Originally Posted by razorlab
Let me know when your 4th gear spits its teeth around your gearbox if you still feel the same way.
i changed it after my 9th event, and the 13th one is coming up, i'll do the swap after 14, just to get on a system.starting to change stuff like that every event is prohibitivly expensive.
Originally Posted by WarmPepsi
yes, but weren't you AND warr running bg 2 when it gave up?
I use Motul for everything from the radiator fluid to the LSD oil in the rear diff. I did that in the old 03 and in the IX I have not had one problem in either car.
PS: I do mine every 15K miles ...
Originally Posted by DaWorstPlaya
+1 ... I think the lubricating and cooling properties of the BG2 weren't up to par ...
Void also had this problem and he was running the stock fluid at the time as well.
Honestly from what I have seen, experienced and heard, the 6spd is a big pile of ****.
No doubt the 6 speed isn't as strong as the 5 speed ... but people tend to play mad scientist by mixing and matching stuff that doesn't always pay off ...
Voids problem was because his wife was resting her hand on the shift lever the entire time she was driving and caused premature wear.
The two guys in the bay area with the same failure as Void didn't have wifes that drove their evos and did not rest their hands on the shifter all the time.
I'm running Redline MTL currently in my 6spd. (as recommended by TRE as well)
I'm sorry you guys are in denial of the pile of crap the 6spd is. Just because it hasn't happened to you it's all roses I guess.
Who wants to start taking bets on whos 6spd will blow up next?
So far:
TTP (4th gear, drag racing)
Warrtalon (4th gear, open track)
Razorlab (4th gear, open track)
Works/SRM-sponsored racecar (broke 2 6spds so far, 4th gear?, open track)
Void (wife)
I'm not in denial, infact I do agree that the 6 speed is not up to snuff when making a lot more than stock power levels. The 5 speed may have it's own weakness, the 1st gear may not be strong enough to take repeated abusive launches, since its only as thick as the 4th gear on the 6 speed (14mm). I've spoken to Jon@TRE about this ... but even you can't deny the weight and the viscocity of the oil and the GL rating were not identical to the stock fluid. Not only that but we don't know what types of additives for high temp and pressure were added to the oil.
Haha, hopefully its not mine that goes out next ...
