Hydraulic Hand Break..Any Body Using?
Old Sep 21, 2006 | 04:34 PM
fbikawi's Avatar
Question Hydraulic Hand Break..Any Body Using?
hi autoxers,
i alaways had the problem of the wide turning radius of the evo when making herpins or small round abouts (360).
i personally find it difficult to use the stock hand break.so i ordered a Hydraulic Hand Break and installed it on the evo....
after tring the hand break for the first time today i managed to spin the car nicely and quickly but there is a problem i cant use the break and the hand break at the same time!! when i press the break paddle the HHB became very hard (by the oil pressure).
there is something wrong with the way my mechanic install the unit or the way he interupted the break oil lines??
Any body is using or can share info. on how to install correctly. please help
Old Sep 22, 2006 | 02:56 AM
fbikawi's Avatar
no body is using?
any mechanical experince will be highly appreciated guys.
Old Sep 22, 2006 | 03:06 AM
mrbkkt1's Avatar
If the hydraulic hand break is tapped into the brake lines AFTER the master cylinder, then the line pressure would be real great on the hand brake.
Old Sep 22, 2006 | 11:40 AM
splurta's Avatar
I would suggest contacting some rally shops as these are most likely to have experience with hydraulic handbrake setups. Good luck!
Old Sep 22, 2006 | 12:13 PM
OliSim's Avatar
Greetings,
Contact WORKS at info@worksmitsu.com We can put you in contact with one of our customers that has sequential shift and a hydraulic handbrake.
Sincerely,
Oliver Simons
WORKS
415-641-9675
osimons@worksmitsu.com
Old Sep 22, 2006 | 02:18 PM
silver04rs's Avatar
Just tighten your factory hand break. If you install a hydro hand break you need to find some sort of way to make it disconect the drive to the rear wheels like th efacdtory unit
otherwise you are going to be buying a new center diff and possibly a new trans very soon
or you could try road racing
Old Sep 23, 2006 | 03:04 AM
fbikawi's Avatar
i will shift the switch of parking light (originally on the hand break leaver) to the new hydraulic assembly.
the ACD system take signal for the Parking brake switch.
so either u are using original hand break or hydraulic it is the same effect on the center diff
Old Sep 23, 2006 | 03:05 AM
fbikawi's Avatar
Originally Posted by OliSim
Greetings,
Sincerely,
Oliver Simons
WORKS
415-641-9675
thanks for the help
Old Sep 23, 2006 | 07:17 PM
Bimmubishi's Avatar
Are you using an AP or Girling type master cylinder for the handbrake? It sounds normal.
Old Sep 24, 2006 | 04:58 AM
WarmPepsi's Avatar
hmm, i guess you'd REALLY not wanna pull that one after a hotlap session
evo_yoshi15
May 9, 2016 01:56 PM
R/TErnie
Feb 10, 2013 06:26 PM
fbikawi
Jan 2, 2008 12:36 PM
VAEVO87
37
Dec 14, 2006 05:26 PM
evotico
Sep 13, 2006 12:06 AM
