Another Clutch Thread
Old Oct 24, 2006 | 09:30 AM
bullfrg's Avatar
My new Evo makes around 370 hp and 370 trq and after an autox school and 5 events (80 launches) the stock clutch has decided to start slipping. What I am looking for is a clutch that can stand up to the power and the hard launches it will get when autoxing. My old car had no clutch issues in 2 full seasons of autox but it made around 100 hp less in its BSP legal setup. I figure if the twin plates keep me from having to change out the clutch one time they pay for themselves, so after doing some research I am down to 3 choices:
Exedy Heavy Duty Twin Plate: Exedy are very popular with the Evo guys and are cheaper then the Tiltons, they are sprung hubs which should make them quiter then the Tilton for daily driving.
Tilton Twin Cerametalic: Probably the best clutch for my use but expensive and has some daily driving downsides. Worth it if better then the Exedy??
Tilton Twin Hybrid: Maybe a little nicer to drive daily but the organic disk will need replaced before the cerametalic, could change to cerametalic when it gets rebuilt if it did not meet my needs.
Thoughts? I know the Tiltons are nice clutches and are maybe the best choice but are they that much better then the Exedy? I heard the Tilton has a new material on their new clutches that is much quiter but that the price has gone up also.
Old Oct 24, 2006 | 11:22 AM
DaWorstPlaya's Avatar
Have you considered the ACT clutch? That may be a good choice ...
Old Oct 24, 2006 | 07:00 PM
DragNRacing's Avatar
I have a couple hundred launches (solo, 1/8 mile, 1/4 mile), numerous solo events, winged warrior, and over a hundred drag runs on my Exedy Twin Disc and it drives like day one. Oh, and about 7,000 street miles too This one clutch has lasted longer in my EVO than 4 different clutches did in my Eclipse with less abuse.
Old Oct 24, 2006 | 09:58 PM
bullfrg's Avatar
I think the ACT would not make it more then one season.
Old Oct 25, 2006 | 11:22 AM
jbrennen's Avatar
Which ACT clutch are you talking about? They make a range of discs, pressure plates, and flywheels, and I assume that durability would vary greatly depending on which ACT parts are used.
My stock clutch gave out over the summer and I upgraded to an ACT setup with the G6 clutch disc (sprung 6-pad race disc). I can't speak to durability yet, but it launches well.
Old Oct 25, 2006 | 12:07 PM
Jeff_Jeske's Avatar
My stocker has been signing off for some time, so I've been shopping around for a new clutch. Believe it or not, I've been able to test drive various EVO's with aftermarket clutches at the track. So far my favorite of all is the Exedy Twin HD. I haven't driving an SD but why even consider it since the HD is super streetable. The Tilton had way too much bite and the ACT HDSS was similar to stock but there has been so much drama involving lockout and constantly changing engagement that I wouldn't give it a second thought.
The only negative thing I could say about the twin was the price. It's costly but in all honesty I don't mind paying more for a clutch and flywheel combo and never have to dick with it again.
I think the best price I had PM'd to me was $1249 shipped + $45 for a new TOB and that was from nolimitmotors.
Old Oct 26, 2006 | 08:22 AM
bullfrg's Avatar
Anyone else have any experience with any or all? Need something that will work for autox and track days but still be daily driver friendly since this is my only car.
Old Oct 26, 2006 | 09:34 AM
jbrennen's Avatar
Forget my setup (ACT G6) for daily driver friendly.
Well, it works for me for street use, but it's not a daily driver, and I almost never carry passengers, so a little bit of rough clutch is not really a problem.
Old Oct 26, 2006 | 09:37 AM
bullfrg's Avatar
That is one of the reasons I was not looking for a puck style single plate, even though they will handle the power and probably take the launching.
Old Oct 26, 2006 | 10:33 PM
TTP Engineering's Avatar
ACT HDG6 is probably along your lines. Sprung 6 puck single disc cerametallic.
Old Oct 27, 2006 | 05:31 AM
I forgot to add that entire stock driveline of my MR is still in one piece after two full seasons with the Exedy too.
Old Oct 27, 2006 | 07:19 AM
swordfish's Avatar
Someone needs to be the new ACT carbon/carbon twin guinea pig.
jeff
Old Oct 27, 2006 | 09:21 AM
992gnt's Avatar
Exedy Twin. It's street driveable, puts up with an insane amount of abuse, and is rebuildable.
Old Nov 4, 2006 | 02:20 AM
trinydex's Avatar
act has a new carbon carbon triple plate... should be the new best solution
Old Nov 4, 2006 | 07:15 AM
bullfrg's Avatar
How much is that going to be? I thought carbon-carbon clutches were not the best thing for daily driving.
