NASA '07 TT Rules
Agreed though, as much as I can afford. But, i was thinking of doing a few events late in the season but won't have a cage then (just an autopower roll bar i have now). Cage coming next winter as i need the car on the road for this year..
Holy crap! I just read the tire rules more carefully. Have I read this correctly??
If I run a toyo 255 RA1 I take five points. Then I get back 10 points!! for being 40mm under the max size for TTA of 295. Is this correct??
If it is, I would have plenty of points available for future mods. I could also take off some lesser mods (rear strut bar, lip, VG/MR gurney flap, bumpsteer kit, LICP) run on 235 RA1's (+5 and -2) and stay in TTB.
Also, can you make major changes to your vehicle mid season as long as you are still compliant to your class?
Thanks for any help.
No. The standard Evo VIII is base classed TTC**. The "standard" tire size for TTC base is 245. That means you get 10mm for free - 235 'stock' to 245 ' TTC standard', and and +1 for the the 10mm to get to from 245 'TTC standard' to 255.
Clear as mud, no?
Clear as mud, no?
2005 Evo VIII:
TTC +14
255 RA1s +6
cams +6
ECU (WORKS P2) +8
TBE not cat +3
Buddy clubs +5
Hotchkis sway +2
Fuel Pump +2
Lower braces +3
Rear strut bar +1
Bump steer kit +2
VG/ MR gurney flp +2
front lip +2
no trunk carpet +1
57 total points to stay in TTA I believe I now have this correct? Greg? Thanks very much for any help figuring this out.
Or take off the front lip (-2) and throw on some stage III WORKS Ohlins
(+4) and be right at 59 (and lose a great deal of weight in my wallet
(note: I do have a stock throttle-body and the +4 LICP
is coming off))
TTC +14
255 RA1s +6
cams +6
ECU (WORKS P2) +8
TBE not cat +3
Buddy clubs +5
Hotchkis sway +2
Fuel Pump +2
Lower braces +3
Rear strut bar +1
Bump steer kit +2
front lip +2
no trunk carpet +1
is coming off))
Stock airbox and ic piping? Boost controller? If no to those two things, you are correct in your points. These five things sure eat up a lot of points:
Lower braces +3
Rear strut bar +1
Bump steer kit +2
front lip +2
That's a lot of tire right there....
I should be at 55 points come April, unless I jump to Hoosiers.
Lower braces +3
Rear strut bar +1
Bump steer kit +2
front lip +2
Thanks Greg!! Drop in filter and no boost controller.
Yeah, if I get my butt kicked by Hoosier equipped cars I might have to bite the bullet and take off the braces, etc. and drop big coin for 245 Hoosiers.
By the way, we will be at Grattan (my favorite- "home" track) in June-have you ever run there?
I don't mean to presume anything, but I could certainly help you there line-wise etc. if you you think it might help you
I can run that track in my sleep, but it has a few tricky spots.
Mid Ohio is the track where I need some seat time. Should be easy, given how often OH/IND runs there.
The "final" rules are posted on the TT website - add another two points for a reflashed ecu... Also the tire points have changed due to our 'base class' tire size changing.
nemsin
Jul 24, 2015 10:48 AM
supersilverMR
Feb 1, 2011 12:44 AM
