Autocross EVO - Street Modified Build
Old Feb 9, 2007 | 07:29 AM
  #181
hokiruu's Avatar
After my first AutoX the absolute first thing I felt I needed was a harness and possibly a bucket seat. I am pretty small and the Recaros could fit me alot more snug, but with a harness, it's a HUGE difference. It is probably the best money I have spent on the car yet. A seat has now taken the back burner for a long time.
Old Feb 11, 2007 | 07:21 AM
  #182
prostcj's Avatar
Originally Posted by LanEvoNine
i'm surprised nobody mentioned seats... i recently obtained a bride zeta iii seat with their fg rails set on the lowest setting... what a difference it makes! i'm 155ish 5'7'' and the stock recaros would fling me around... but now with the brides i'm glued to the seat and i noticed i can corner without bracing myself and feel in full control, my level of control has greatly increased; feels like i'm one with the car...can't wait to autox in them, those seats/rail combo are also lighter than the stock combo so you save a few lbs near the front axles...
I wish being flinged around in the stock seats was a problem for me.
Old Feb 12, 2007 | 07:32 PM
  #183
mannymartinez's Avatar
ok this popped in my head breifly...
since im the "on a budget SM" car here. lol
do u guys think with the 17x9 5zigens and 255/40 tires i can run a small spacer up front. or dont even worry about it. i know some guys like to have a good size spacer but with the 18x9.xx+
only less than a month away before my regions first test and tunes start. cant wait!!
thanks
Old Feb 12, 2007 | 08:41 PM
  #184
Warrtalon's Avatar
I don't think anyone LIKES having a spacer. We generally try to avoid spacers at all costs. For what reason do you WANT to use a spacer?
Old Feb 13, 2007 | 04:18 AM
  #185
kekek's Avatar
They allow you to use the same size wheels while widening the front track. If you do this it'll help your tires last longer since you can rotate them frt to rr. I found it especially useful with the 710's last year. The main problem becomes replacing only 2 tires and you end up with a mismatched set where your fronts are new and grippy and the rears are partially heat cycled and the balance of the car shifts.
I think for autox it's not really such an issue as driving on the track with the higher speeds and continued loading through long corners.
Old Feb 13, 2007 | 04:39 AM
  #186
Mad_SB's Avatar
I think robi uses them in some if his "kits" to widen the front track for better turn in. That is the theory anyway IIRC.
Old Feb 13, 2007 | 08:07 AM
  #187
Warrtalon's Avatar
Ah, ok. I was thinking from the road racing perspective where you try to avoid it.
Old Feb 13, 2007 | 08:10 AM
  #188
i'll try to get my hands on 5mm and see if it helps. i'll do the first session with them off and the second send session with them on and see if i notice improvement.
Old Feb 13, 2007 | 06:34 PM
  #189
kevo's Avatar
Manny, I don't think you will notice any differences with or without spacer performance wise, with 17x9 wheels (35 offset) and 255 tires, you shouldn't run into any clearance problems.
Kev
Old Feb 14, 2007 | 08:41 PM
  #190
Ultimate CC's Avatar
the people running 285s, are you removing the fender liners or are you just leaving them in and rubbing slightly?
Old Feb 14, 2007 | 08:57 PM
  #191
Warrtalon's Avatar
Check out my build-up thread. I just rolled the fenders front and rear - no rubbing during my one auto-x, but I haven't put it to the test on the road course yet - not until Mar 17/18.
Old Feb 14, 2007 | 08:59 PM
  #192
aright thanks...i really need to get on ordering up coilovers and tires...
Old Feb 14, 2007 | 09:16 PM
  #193
Lil red '03's Avatar
Subscribed - great thread.
I'm currently running STS but i'm going to make a jump in classes when i purchase my evo in the fall.
Old Feb 15, 2007 | 08:58 AM
  #194
EVOlutionary's Avatar
I rubbed throught the fender liners with my '04 275/40/17 setup, but with the 285/30/18 setup have had no rubbing issues. I think the rubbing has alot more to do with diameter than width, at least UP TO the 285 mark.
EVOlutionary
Old Feb 16, 2007 | 07:21 AM
  #195
chrisw's Avatar
EVOlutionary
sort of. The sectional width of the kumo v710 in a 285/35/17 is 11" while the same tire in a 275/40/17 is 11.4"
I think the contact patch remains about the same due to the different profile of the tires.
