Hubcentric wheel spacers with autox
I'll be running FN01r-c 18X9.5 with 285/30 A6's for autox this year. Is there a need to run hubcentric spacers for autox speeds? I'm trying to keep this as simple as possible and would prefer to run without the spacers when on my stock wheels.
Is there a kit that doesn't require removal of the stock studs with 10mm spacer?
With those wheels you will definitely need longer studs or a "bolt on" spacer if you run any spacers. Thread engagement is pretty low without any spacers. I had Fred make me a set of 10mm spacers, but I run the longer studs from RRE.
You could also look into KICS, as they make some nice spacers w/built in studs, but I don't know how thin they go. I think per the link below, it is 15mm min for a spacer with a built in stud.
http://www.mackinindustries.com/wm/kics/kics.html
The Kics ones do exactly that, they attach to OEM studs. A couple friends of mine have them and are quite happy. These are autoxers who's cars see 20+ events each year. If I were to get some now I would try the 15mm Kics spacers with those wheels (I have same). I would feel pretty comfortable about them on the 285 V710, although I hear the A6 is wider, so you might expect some fender contact. I also run about -3 camber, so that helps fender clearance a bit.
OK, this is what I was looking for. I know I have to roll the fenders. I'm going to check to see if wheeladapters.com can make me some at 10mm. I don't want to push out my wheels too far since I'm running -2.5 in the front instead of -3.0. Maybe it's time to step up to a -3.0 camber. I'm just afraid of my regular tires wearing out too quickly.
It's an effective 25mm offset (10mm spacer in front). Only times it has ever rubbed was hitting a good sized bump mid corner on course. That's occured maybe a handful of times all year (20 events give or take).
With longer studs you could also use open lugs for stock wheels, or just use the spacers with stock lugnuts.
Fred at wheeladapter said he wouldn't make bolt-ons less than .80" (20mm) thick, because there wasn't enough meat for the studs he uses. Kics from Mackin seem like the only chioce if you go thinner.
Vizzle
27
Apr 17, 2015 12:13 PM
