View Poll Results: Which evo for roadrace (multiple selections allowed)
RS (03-06)
39
62.90%
VIII (03-05 anything)
11.29%
MR (05-06)
6.45%
IX (2006 anything)
18
29.03%
Multiple Choice Poll. Voters: 62. You may not vote on this poll
Which model is best to track (road-race)?
How much standing water are we talking about? Its almost worse here up north. Instead of lots of standing water, Infineon with its hills and poor irrigation means we get rivers, right at the apexes! In those cases ABS certainly provides a good safety margin. Should just means driving up to the limit much slower than normal though. AWD isn't a magic bullet, neither is ABS.
Normally though, you shy away from that much rain, and let the downpour let up, however, it is a blast and a rush to be out in it
Much worse than pools of water is when you have a line of water running at an ange to the track. There's a river that runs diagonally across the exit of the carousel at Sears Point that has eaten a lot of cars.
I run an 04 RS, as mentioned previously. I've been very happy with the decision for three reasons:
1. Standard front LSD saves $$$
2. NO ABS...I prefer no ABS because having full control of the brakes is more important than a occasional wheel lockup...sometime I don't care if one wheel locks a little, and sometimes you can get really ****ed by the ABS not wanting to lock the wheels and lowering brake force all around...it should be noted that I use the brakes to make the car turn often, and ABS isn't always on the same page with this technique.
3. NO ACD...its a lot easier to make the car handle well without the complexity of ACD. This became apparent when we tried to transfer my race car setup to an ACD equipped car, and everything became a bit more complicated because of the dynamic nature of the ACD control. Not to say ACD isn't good, just not for me.
+1...but there is another reason to NOT get the RS...Electronic Brakeforce Distribution (EBD). Without it, you'll be fiddling with a crude manual brake bias knob if you don't want to smoke your inside rear tire trail braking into a corner.
As for being without ACD, I'm inclined to agree that that might make sense. The diff behavior on my car seems inconsistent at times, and I'm hating the additional variable while trying to set up the car. After driving an Audi 4000S with a locked center diff and a Subaru with a fixed distribution front-to-rear, I'm thinking that something similar ont he Evo would be the right answer.
All that said, I wouldn't go with an VIII simply due to the MIVEC head. The flatter power curve makes the car easier to drive and it should ultimately be faster. Just got to figure out an answer on replacing the ACD..
